What is your MPG for a non-overdrive LS motor
I swapped in a LQ9/th400/3.27/tight(er) converter into a 96 Stang (somewhat lighter) and it looks like 14-16 is about it at ~65mph. RPMs are 2500-2750 which I think is the culprit, but I would of thought a 364" motor with high gears and a 15:1 AFR at cruise and 36* of timing would be close to 20 mpg. Seems like most guys are getting that...unless their speedo's read way too fast
RPM that high will kill your highway mileage no matter what. The inefficient drivetrain is also going to rob you of efficiency.
My stock 6.0 with a factory converter and 4L65E could get low 20s on the highway running 2000-2200 at aroung 65mph. At 2700 it would be in the high teens. So while yours doesn't seem that far off, I'm sure you can improve on it...but not much more.
My cruise AFR is 15:1, plenty of spark timing. Can't go too much leaner, and even if I did it wont make that big a difference. Unless my spark timing is way off (36*).
If I could knock-off like 500-700 rpm that would make a work of difference I bet.
I do have 83lbs injectors vs the 60lb in the Chevelle and an LS6 cam vs stock also in the Chevelle, but cant see it making that mucha difference???
Do they make a "locking" converter for th400? I thought the trans needed to be internally designed for a lock-up converter.
Sell the convertor, at least grab a locking 400. Gas cost too much imo unless you don't drive it much. Locking it up while cruising makes a huge difference in rpm and fuel mileage. I don't know what the specs are on your current convertor but I'll bet you will see 500 rpm drop cruising if it locked up.
