General LSX Automobile Discussion Non-technical LSX related topics.
vats problem
Old 10-25-2015, 08:12 PM
my00ta's Avatar
Default vats problem
I have a 2000 trans am my steering column is in bad shape I am going to get another one from another 00 ta if I get the vats box with the other column and install both in my car is that all I need to do im sure the keys will not be the same resistance
Old 10-25-2015, 09:37 PM
sawblade99Z's Avatar
You'll probably need to get a copy of the key that comes with the new column made from a blank with the correct resistor pellet. I'm pretty sure the correct resistance for the ignition is stored in and read by the BCM.
Quick Reply: vats problem
