best motor oil and rear end gear oil?
Got 1999 camaro with some upgrades and a 410 rear end. what would you all recomend for oil and gear oil. just bought it couple months ago and dont know what previous owner put in it/ or when.
Can't go wrong with Amsoil. Even though it's full synthetic, you still may get some chatter. The cheap Auburns GM used will chatter until an additive is used. But sometimes not. It's good to add the additive anyway.
As for the engine, Sig series or Mobil 1 are both good. Just more frequent changes with Mobil 1.
I'm an Amsoil dealer but don't push it. People have their opinions so I don't push it unless they want it. STAY AWAY from that Purple garbage.
Or I also recommend Brad Penn oils....good stuff.
If you want Amsoil, you can buy directly online. You can try the dealer locator but there may be a smaller dealer very close to you but Amsoil doesn't list due to certain criteria a dealer must meet to be listed on the locator. It's BS but thats the rules they have.
yeah i have heard mix opinions ont he "purple garbage" i had a caliber srt4 previous sold for this and all i used in that was moblie full synthetic one. so i may just stick with moble one engine oil. but the rear end is new so i wnat to change it since it has just broke in.
If you don't want to pay the bigger $$ for the boutique brand motor oils I'd go with either Mobil 1, Pennzoil Platinum, Castrol Edge, Valvoline Syn-power, etc. Those can be found cheap at Walmart or your local auto parts shop. Some slight variations in their blends as Mobil 1 is light on Calcium and heavier on Magnesium. Castrol is very heavy on Magnesium, while Pennzoil sticks with the tried and true heavy Calcium additives like 80% of most manufacturers. Valvoline uses a lot of Sodium (almost no Mo or Boron) as some of the specialty brands do (Royal Purple, Lucas, Shaeffer, etc.). The Amsoil OE tests out very similar to Formula Shell, Kendall GT, Super Tech and Mobil Super Synthetic.
Personally, I like the Penn Plat and Mobil 1. You might want to consider a 0w-40 grade for a little more higher temp/high shear protection if you're going to push the car hard frequently, track it, or race it....especially in a warmer weather climate. The regular 5W-30 wt oils tend to be weaker 30 weights that can shear down to 20 weight before the oil change interval is up. The 0w-30 wt oils tend to be very strong 30 weights. So you can get there that way too. For typical driving conditions a 5w-30 is ample protection.
http://www.pqiamerica.com/March2013P...sallfinal.html
Let me tell you I've worked on 100's of rears so I'm telling you from experience. STAY FAR away from Mobil 1 gear oil....in fact RUN AWAY from it! Its complete UDDER BS GARBAGE OIL marketed to the rich fools of the world.
There are a few good gear oils out there, IMO Amsoil is at the top followed by shell Rotella products and so on.
I posted it because most people seem to go with that horrible crap. Even the cheapest regular gear oil is better than Mobil 1 gear oil. I could tell you story after story about it failing. Its so bad Mobil should remove it from service but then companies like Ford etc wouldn't rake in out of warranty repairs and parts money. Its the factory fill in a bunch of different major manufacturers rears. It should be renamed Mobil 1 Wallet and Purse cleaner.
LS1Tech Administrator
Received 1,488 Likes
As the OP's car is a '99, it would have the Torsen. Additive isn't required for this rear but it certainly won't hurt either; frankly, it will chatter under certain conditions no matter what gear oil/additive combo you use. I've owned several of these rears, including in F-bodies that I'd bought brand new, and they chattered from day one under certain repeatable road conditions (especially coasting on uneven ground or curves.) The Auburns are actually much quieter, but they do in fact require an LSD additive (work best with GM brand IMO) and you don't want to use a synthetic with them. '98 was the last year for the Auburn as standard issue in the 4th gens.
Location: Grew up in Charleston, SC live in Moncure, NC
Someone on another forum I belong to says that is what all the Nascar guys use...
