General LSX Automobile Discussion Non-technical LSX related topics.
1 thread 2 questions.
Old 11-05-2015, 03:26 PM
allmotor1's Avatar
Default 1 thread 2 questions.
so i have a 418 ls3 in my fbody and today on the water temp it got to the next notch from 210. i put the heat on and it went back to 210. and went back up when ac on. is this hotter than usual? and also i pulled my oil fill cap off while the engine was running and very light vapor was coming out not puffing out just like verly lightly coming out only when i took the cap off. put it on and off a couple times and it started to not really have vapors come out, is any of this normal and if so what should i do?
Old 11-05-2015, 05:09 PM
allmotor1's Avatar
Any inputs about either? Anything's appreciated
Old 11-05-2015, 08:42 PM
murphinator's Avatar
do you have a scanner ? I dont trust the f body gauges much but would trust obd2 data
Old 11-05-2015, 09:30 PM
allmotor1's Avatar
no scanner at moment but will have access to one in a couple weeks. im really worried but i do know that the guages are not the most trustworthy but what would make the gauge go that high even if it wasent that hot?
Old 11-06-2015, 04:59 PM
allmotor1's Avatar
Update: problem solved I had taken the air dam off when I changed the oil I took it off and it just hit me today that I forgot to put it back on. So I put it back on went for a drive and coolant temps were perfect.
Quick Reply: 1 thread 2 questions.
