LSX Build - Looking For 8's
This is my first LS build and as such, am a total newbie! I have been researching this for a few months now and have just put together a little combo I HOPE makes sence and will actually work!
Can people help me out? any advice? The complete engine is going to be built from the ground up as a stock LS3 over here costs around $7,800 and thats before any upgrades take place. It is much cheaper for me to build from scratch buying parts from over the pond.
I want to run on E85
Looking to get into the 8’s
Car will be 90% track, 10% street.
GM LSX 9.240 Block - $2625.97
K1 Forged 3.622 Crankshaft w/ GM 58X Reluctor Wheel - $835.44
Callies Compstar H-Beam 6.125 Rods, 2.100 Journal, 0.927 Pin - $665.00
Wiseco Forged 4.070 Dish Pistons - $847.50
BTR Custom Turbo Cam - $389.00 (Need advice on duration/lift/lobe)
King Main Bearings - $105.95
King Rod Bearings - $59.95
Durabond Teflon Coated Cam Bearings - $60.00
BTR Ported LS3 276cc Cylinder Heads w/ BTR .660 Springs & Titanium Retainers - $1699.00
Comp Chromoly Pushrods - $175.99
Comp Ultra Pro Magnum Rockers w/ Studs & Guide Plates - $534.95
Morel .903 Ultra Pro Solid Roller Lifters - $799.00
Smith Brothers LS Bronze Bushing Trunnion Kit - $159.95
Melling High Volume High Pressure Oil Pump - $155.95
FAST LSX 92mm LS3 Intake Manifold - $829.00
FAST LSX Big Mouth 92mm Billet Throttle Body - $390.00
FIC 1100cc Injectors - $950.00
Holley Dominator Billet Fuel Pump - $432.95
Precision 88mm T4 .96 A/R Turbo - $1699.99
This is what I have so far, any help, advice and tips will be much appreciated!
What kind of car ?
Where are you? Just curious if this is your first LS build it sounds pretty ambitious. I would check out the boosted forum to see who can help with a cam selection. You could try talking with Arun, he has been specking cams for super charged builds. He may be able to help with a turbo cam.
https://ls1tech.com/forums/member.php?u=7631
I am in the UK.
It is ambitious, but I am an ambitious type of guy. It is going to cost me around $7,000 for just a STOCK LS3 where I am, so i thought id spend a little extra and get a HUGE increase if you get me?
As DADDY J stated, this will be going in an 2004 Mustang which weighs approx 3250lbs? the interior will be stripped and some lightweight items added so not 100% sure on final weight, I will also be running MT 275 radials 90% of the time, unsure on transmission as of yet.
Or, if anyone else can assist, I have a budget of say, $15,000 and want to make as much HP as I can from an LS series motor, what options and combo's are available to me?
http://www.superchevy.com/how-to/engines-drivetrain/1408-1113-hp-destroked-ls-build-heavy-hitter/
This should do the trick!!
