Tdc method valve spring change question
Posted this in the engine section but no help, maybe anyone over here has some info
I changed my cam and i am about to change the valve springs. I am going to use the TDC method that has been described very well on ls1 how to. My question can i leave the plugs in the head? other than the people who like to double check with a straw or a stick to feel if its at TDC is their any other reason to take them out? i also know that it would make turning the engine over easier but i am not worried about that. I am just trying to save some time, and my knuckles if possible. Thanks
You need to remove the plugs. You can then stick a small object through the holes to feel if the piston is at the top. If taking plugs out was something that bothered me like this, I probably wouldn't be attempting cam swaps on my own. Risking a dropped valve for the sake of not removing plugs is mind boggling to me, you would have a much bigger job to deal with than just removing plugs... You should be able to remove them all in about 20-25 mins at most. I find cylinder 8 easiest to get from underneath the car.
Also just noticed this is an old thread... So I hope it worked out ok.
Yes, you can leave the plugs in if you like. Just follow the procedure exactly as described on ls1howto.com.
I just did my cam/spring swap and followed the same procedure. I did have my plugs out, but followed the instructions to the letter and didn't have a single issue. If you make sure you follow everything as described you will have zero issues.
