SLOW window motor and the motor is NEW!
I just bought a brand new Dorman window motor for my pass side window and had it professionally installed. The damn thing is slower than a dead fricken turtle!!!
I thought maybe it was the old tint causing drag, but I've removed that and cleaned the window.
Anyone have any ideas?
That will suck if I got a bad motor, but at least it does have a lifetime I had this pro installed, meaning rivets, not self taping screws.
What is the motor mod?
I thought I had read on here, or some other forum, that there was a new motor design, but can't find it again.
No, I thought I had read that there was a new design other than the pancake (I think that's what these motors are called) motor.
The window looks like it's struggling to go up, like there's a lot of drag on it. Just real slow, especially right at the end when it's about fully up. I'll try to get vid.
Oh man, LMAO, I really needed the laugh this morning and that comment brung it!😂😂😂
This is the type of stuff that happens to me all the time😂
Seriously though, I hope you get it figured out. I'll be changing mine someday soon as well.
LS1Tech Administrator
Received 1,484 Likes
I don't think there was ever a new regulator design, but for a while there WAS a new motor design being sold under the Dorman name. That motor seems to have disappeared though, and they are back to the original design. All of this was outlined in a power window motor thread in the Firebird section I believe.
As for "professional install", if they removed the entire regulator I certainly hope they used the proper rivet to remount it to the SMC inner door structure. This is a special rivet available from GM (and perhaps other sources) that won't enlarge the mounting hole over time (this is not a problem you want to have, very difficult to ever fix.)
If it was just a motor swap, there is no reason to use rivets again. And I don't know why anyone would use a self-tapping screw, just a machine screw with a nut (lock nut would be best) on the back side. You can use a bit of loc-tite if desired, but I've never bothered to and never had an issue.
I don't see much value in the hotwire kits for the passenger side window, personally. On my highest mileage 4th gen, the passenger window motor outlasted the driver side motor by many years, so I don't think the voltage issue is really that big of a deal (unless maybe you're in the habit of rolling them up and down simultaneously, and/or with the engine off.)
