HELP! identify this supposed LQ4
Thank you. To be more specific, I'm trying to find out the year. Good rods and floating wristpins vs pressed pins, etc. Also, where would I find the entire VIN. Dealing with a shady junkyard and want to verify mileage and donor vehicle.
I don't think they ever stamped the VIN into the motor. Is it DBW or DBC? 317 heads means it's no older than 2000. 1999 was the last year for the iron headed LQ4 (that is what i have)
Then a large 8 underneath
0309120964922319 - etched on top side on head, drivers side front
3091T5722363 - etched on top side on head driver rear
Restricted User
If it comes with absolutely everything, $1200 is in the ballpark of what they normally go for.
Unless you plan on adding lots of boost, the floating pin rods aren't necessary.
BTW, I decided to go with another 6.0. This one was too sketchy, dirty, mileage unknown, and looked like it was pulled out by a monkey.
