General LSX Automobile Discussion Non-technical LSX related topics.
Beating a 350Z
Old 12-07-2006, 06:05 PM
SSCamaroUSMC's Avatar
Default Beating a 350Z
Car & Driver specs.
Aug. 2002 (2003 350Z?)
0-60 = 5.4 sec.
14.1 @ 101 mph
(2000 Camaro SS)
0-60 = 5.5 sec.
14.5 @ 103.5 mph
Any tips on beating a 350z? I'm pretty slow on the launch.. I looked for a newb guide on how to launch properly, but i really dont want to screw up my tranny messing around not knowing wtf im doing.... can someone school me on proper launch (street tires, stock 2000 ss convertable (got flowmaster exhaust))
help?
SSCamaroUSMC is offline
Old 12-07-2006, 06:14 PM
SDfbody's Avatar
I pretty damn sure a 2000 SS will run better than a 14.5. That's a horrible time for a ls1.
As long as you don't completly screw the launch, you'll beat a 350z.
SDfbody is offline
Old 12-07-2006, 06:16 PM
Revelation Z28's Avatar
anything with 250+hp can beat one with a good driver.
Revelation Z28 is offline
Old 12-07-2006, 06:21 PM
Ell Ess Won's Avatar
lmao at car and driver.
Ell Ess Won is offline
Old 12-07-2006, 06:22 PM
boostedbuford's Avatar
With those times Car and driver must have put 215's out back
boostedbuford is offline
Old 12-07-2006, 06:24 PM
Vicious.'s Avatar
Is Car and Driver the worthless magazine, or is it Motortrend? I forget.
Anyway, don't go by times that you read. From what I've noticed around here, unless you've never tried racing your car or are at some crazy elevation, mid-13's are about normal for an F-body. You *could* be a little slower since you're in a vert, but 13's should still be easy. Therefore, you shouldn't have much of a problem with any 350Z you come across, unless it has an experienced driver or some kind of FI.
Vicious. is offline
Old 12-07-2006, 06:29 PM
Iron Sights's Avatar
Both.
Here's what you need to do to win:
1. Stop magazine racing.
2. Start car.
3. Drive car to place where race will occur.
4. Apply throttle.
Seriously, as long as you don't completely blow the launch, you will bring home a win. Stock for stock, a 350Z is no match for an LS1. With a competent driver, your car is capable of low-13s @ 105-108.
Iron Sights is offline
Old 12-07-2006, 06:30 PM
jpat1023's Avatar
The only tip you need for beating a 350z is this: press the pedal on your right all the way down. That's it! ......and those numbers are wrong. 14.5!!? If thats what your running, sell your car...
By the way, you have this situation completely backwards. The 350z is at a disadvantage, not the SS!
My advice to you: Spend as much time as you can on this site, will be the best thing you can do for you and your car.
jpat1023 is offline
Old 12-07-2006, 06:33 PM
JD_AMG's Avatar
Originally Posted by SSCamaroUSMC
Car & Driver specs.
0-60 = 5.4 sec.
14.1 @ 101 mph
(2000 Camaro SS)
0-60 = 5.5 sec.
14.5 @ 103.5 mph
help?
Post the article with the times the Camaro made, that has to be a typo, or they launched in reverse, turned around and finished the 1/4 mile. My very first time at the dragstrip with no prior racing experience I ran a 13.7@104.
Do you have an A4 or M6?
http://www.stangbangers.com/01_Cobra...SS_Article.htm
http://www.stangbangers.com/98_Cobra...rd_Article.htm
If your not able to beat a 350Z something is seriously wrong...
JD_AMG is offline
Old 12-07-2006, 06:37 PM
we_todd_did's Avatar
Look this is what you do, rev to rev limiter then dump the clutch soon as you hit the limiter shift and repeat.
we_todd_did is offline
Old 12-07-2006, 06:38 PM
JD_AMG's Avatar
He said he wanted to beat a 350Z, not put on a smoke show...
JD_AMG is offline
Old 12-07-2006, 06:40 PM
87gnx's Avatar
Are you an auto or manual?? Either way you shouldn't have much problem if he's stock.
87gnx is offline
Old 12-07-2006, 06:42 PM
Speed's Avatar
14.5? Maybe in reverse. Any halfassed driver should be able to pull down a 13 second 1/4 mile in an ls1 car. Keys to launch on the street with no traction, just don't slam it to the floor or your blow the tires away. Keep it under control and roll into it. Then wave goodbye to your buddy in his 350z...
Speed is offline
Old 12-07-2006, 06:47 PM
So proper launch, rev to like 3k, release clutch? heh.... remember.. im a noob.
Old 12-07-2006, 06:49 PM
JD_AMG's Avatar
On the street I would launch at like 1500RPMs, at the track maybe 2000RPMs. Just get out and practice in a safe, deserted area.
EDIT: and seriously, where did you get those times?
JD_AMG is offline
Old 12-07-2006, 06:50 PM
and how much of a disadvantage does a convertable put me at?
Old 12-07-2006, 06:51 PM
JD_AMG's Avatar
A few tenths of a second at the worst, shouldnt make that much of a difference.
JD_AMG is offline
Old 12-07-2006, 06:53 PM
Speed's Avatar
Sorry, I thought it was an auto for some reason. No, with cold tires and pavement, revving to 3K and dropping the clutch on full throttle equals spinning tires. I would leave like you are leaving a stop light and trying to get in front of someone to get over a lane. Once you are rolling a bit, you can roll gently but quickly into the throttle paying attention not to break loose. Once your there, drive it like you stole it!
Speed is offline
Old 12-07-2006, 07:52 PM
BLKWS.6's Avatar
DO NOT DROP THE CLUTCH! Hell, you could launch off idle and run one of THOSE things down. SS>350Z any day of the week.
BLKWS.6 is offline
Old 12-07-2006, 08:14 PM
StealthZ06's Avatar
They are slow as molasses. Barring driver error, you will stomp him into the ground. I drove one a few months back, I was thoroughly disappointed by the lack of power.
StealthZ06 is offline
