General LSX Automobile Discussion Non-technical LSX related topics.
how many quarts
Old 01-31-2007, 01:19 AM
fuseone's Avatar
Default how many quarts
how many quarts of oil does a ls1 take?
Old 01-31-2007, 01:35 AM
blue02formula's Avatar
My car takes 5.5qts. if you use a longer oil filter 6qts.
Old 01-31-2007, 01:38 AM
zach_ws6's Avatar
just put 6 qts of mobil 1 in my beast today
Old 01-31-2007, 01:46 AM
Blk97WS6's Avatar
i use 5.5 quarts with a standard size filter.
Old 01-31-2007, 02:13 AM
BLKWS.6's Avatar
6 qts stock filter 6.5 or so with a longer one. You have a lot of room in the oil-pan and it wont hit the crank with even 7qts. Also, you have to take into account .5-1qt will NOT be in the pan even with the engine just idling.
Old 01-31-2007, 02:46 AM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,458 Likes on 1,051 Posts
Owner's manual says 5.5 quarts, but I usually run more like 5.75-6.0.
Old 01-31-2007, 05:50 AM
02 SOM WS6's Avatar
5.5 but 6 qts is fine. I have had an LS1 since March of 98. Actually 2 different ones, and they have had 6 qts in them at almost every oil change. It won't hurt a thing.
Old 01-31-2007, 06:23 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
5.5 quarts shows up to the full mark on my dipstick. I wouldn't put any more than that in the engine unless you're running a longer oil filter or deep oil pan.
Old 01-31-2007, 07:53 AM
SHINER's Avatar
If you can, put in stock Filter(AC Delco PF46) and 5.5 qts of oil.
If you put over 5.5 qts of oil in a stock filter size you will create windage and will make the characteristics of the oil change because of how your crankshaft(oil slapping your crank from being to full) will "aeroate"(sp?) and will basically cause your oil pressure to drop and/or oil to start foaming up.
Travis
Old 01-31-2007, 12:29 PM
BLKWS.6's Avatar
Travis
Un-true. The oil level in the pan even at 7qts is below the crank.
https://ls1tech.com/forums/showthrea...+hitting+crank
Old 01-31-2007, 12:36 PM
SHINER's Avatar
You can do what you want, 5.5 is what the manufacturer suggests for a stock oil pan, and also I used to use 6 qts. then I had fluctuating oil pressure(most likely due to windage) I have stopped doing that, and just using the recommended 5.5 qts and it does not do it anymore..
Old 01-31-2007, 05:08 PM
'Bird Director
y2k_ta's Avatar
If you use more than necessary, that's just more oil that your motor has to push around. If there isn't room for that extra oil, then you've got problems like SHINER mentioned.
Old 01-31-2007, 05:16 PM
greysteel_M6's Avatar
I do what the engineers who desinged the block suggest should be put in. 5.5qts
Old 01-31-2007, 05:32 PM
LS1>girlfriend's Avatar
i too put in 5.5qts. hey...its recommended
Old 01-31-2007, 05:40 PM
tboysen00's Avatar
i used to put 6 then i would get the oil pressure jumping around. then a shop told me to use 5 so the crank isnt soaking in it, so i put 5.5 in and the oil preasure stays steady now!!!
Old 01-31-2007, 06:33 PM
Kalgorn's Avatar
5.5 for me.
It's what my manual and this forum recommended so that's what I do. No issues.
Old 01-31-2007, 06:36 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Old 01-31-2007, 06:53 PM
Sharpe's Avatar
True dat. Causes loss in power too. Read a write-up in a magazine about it. (aerate)
I gained a noticeable amount of oil pressure on the car's gauge using a stock-sized K&N going from 5.5 quarts (like the manual says) in my first and second changes to 5 quarts in my third. Now I run 5 quarts and drive it like I stole it. Also, it doesnt use any oil like it did when I used 5.5 quarts. Always stays right dead center in the range on the stick for all 3,000 miles.
Old 01-31-2007, 07:01 PM
BLKWS.6's Avatar
2 schools of thought on this I guess. Patman needs to chime in!
Old 01-31-2007, 09:10 PM
NDFORSPD's Avatar
yeah def need patmans input! I always use roughly 5.5-5.75 qt/change and it doesnt always use exactly the same. lol since my changes in the TA are rare, I take my EXTREME time, let it drain for 2 hrs, slap on a filter(pre-filled with oil), and then add in the full 5 qts(incl the bit put into the filter). At this point I lower the car onto the level garage floor and fill it to the full mark adding/checkin with every 100 ml after that initial 5 qt, lol a 15 min process lengthened out to 3 hrs! not to mention a few beers have to suffer!
I thought oil pressure fluctuation(on the gauge) was normal?
Does the block retain any oil within the veins or any part? Or no matter what, it all drains to the bottom and it just depends on how long you let her drain?.
Quick Reply: how many quarts
