General LSX Automobile Discussion Non-technical LSX related topics.
Clutch fluid?
Old 02-06-2007, 06:43 PM
BLKWS.6's Avatar
Default Clutch fluid?
Is that what lives in the LITTLE white cup in the upper right-hand corner of the engine bay with 1 rubber hose coming out the bottom of it and a cap that says "fill to step" DOT3 Brake Fluid only?
If so, I stuck my finger in it (Damn that sounds bad when referring to unknown mechanical things) and it came back with what looked like baby oil on it. Clear and scentless. Guess this means im in good shape? Is it normal for it to be this clean after 78K miles?
Old 02-06-2007, 06:52 PM
Starz T/A 17's Avatar
Both the clutch and brake resivars (SP) are in the right hand corner of the engine bay and both have white caps, both take dot 3 break fluid, and yea if its clear then its in good shape, Not sure of the life of it though, usually I only mess with it if A. Im having hyrolic problems, or B. Im changing the clutch or master or slave cylinder
Old 02-06-2007, 07:22 PM
BLKWS.6's Avatar
It isnt the brake resovoir. That one is about 4x as big.
Old 02-06-2007, 09:13 PM
HeapaShifter's Avatar
I was worried that you weren't going to start a new thread today.
The clutch fluid reservoir is the small round one (you found it.) The fluid should almost be a honey color. When it turns black (like mine always seems to be) it means the fluid got heated or dirty and should be changed.
Old 02-06-2007, 09:19 PM
BaddillaK's Avatar
on topic: so how often should you change the fluid if it isnt burnt and dirty???
Old 02-06-2007, 09:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Mine is black as sin, but I need to get a new master that is not a mcleod. They suck *** from my last/past experiences.
Old 02-06-2007, 09:35 PM
BLKWS.6's Avatar
Mine was all but clear (on my finger tip). I guess in a large quantity it would be honey colored. Sounds like I am in good shape, awesome!
Old 02-06-2007, 11:36 PM
SladeX's Avatar
If you can see to the bottom of the cup, you're alright.
I had issues with mine being a bit black, turned out the cat was frying the fluid with it's location. I had to insulate it with rubber hose and move it a bit into what I think is supposed to be it's normal area. It's been clear ever since.
Old 02-06-2007, 11:41 PM
BLKWS.6's Avatar
I couldnt see through the fluid. The cup had a plack liner and thus the cup was rather opaque.
Old 02-07-2007, 12:15 AM
StripedZebra's Avatar
If the fluid is black, how do you change it?
Old 02-07-2007, 12:17 AM
BLKWS.6's Avatar
ghetto way: turkey baster...suck some out. Put some in, drive, repeat.
Old 02-07-2007, 12:20 AM
Question
Seriously...? Just till its not black anymore then eh? Pretty cheesy.
Old 02-07-2007, 01:09 AM
BLKWS.6's Avatar
Hey...its a bitch to bleed it.
Old 02-07-2007, 09:43 AM
greysteel_M6's Avatar
I concur. I just did this, wish I knew about the turkey baster.
Old 02-07-2007, 09:48 AM
keliente's Avatar
Take the cap off and remove the black cup. Then you can see the fluid.
Old 02-07-2007, 01:26 PM
Revelation Z28's Avatar
that black cup or "condom" is to prevent moisture from getting in the brake fluid.
