What can I use to clean my garage floor?
I know a lot of people use cat litter when they spill oil but never picked it up so what can be used to clean the floor. The reason I ask is it looks terrible and I'm suppose to be doing anything kind of maintenance. So if you know of anything that works please let me know. Thanks Joe
yea is it like oil stains? What I found works good is get some purple power (or any strong cleaner) spray it down and let it sit for a while, then scrub it and spray more and put cat litter or oil dry down and it will soak it up, I worked at an auto parts store for a while and someone told me to do this and I was suprised how well it actually worked
1 Post
Kitty Litter = OIL DRY (tm) A clay litter-like compound used to soak up oil spills. Sweep up when oil is soaked in. Move it around while it's soaking, step on it, grind it in, move it back and forth. Works best in warm weather. Throw away when done with it. If it hasn't been used up or is lightly used, I keep mine in a small bucket ready for use, with the rest of the bag under the workbench.
Eglin AFB? There should be some liquid cleaner (acidic) available at the BX, Commissary, shoppette(s), or base gas station(s). Follow directions. Get a stiff bristled brush to work it in and around with.
Ask the housing office if they recommend anything. There should be something in your housing package.
Nothing I ever used was magic. It all took a lot of work.
1 Post
I removed all the ribs by breaking them off with a pair of pliers. Twisting worked best. Then I got a burr on an air grinder and cleaned them up. No idea how much better it flows, but it had to do something good.
