General LSX Automobile Discussion Non-technical LSX related topics.
Aviation gas (100LL) in my 2000 Z28
Old 03-06-2007, 11:52 AM
tx77015ls1's Avatar
Default Aviation gas (100LL) in my 2000 Z28
I work at a airport and can get 100LL (Low Lead) gas for cheep.
How would this work in my 2000 Z28?
Thanks, jason
Old 03-06-2007, 12:30 PM
sprayjunkie's Avatar
Your O2 sensors aint gonna like it after a while...
Old 03-06-2007, 12:39 PM
Ericbigmac83's Avatar
im more curious about why you want to do it and what good you think it will do you??
Old 03-06-2007, 12:41 PM
NKAWTG...N
StoleIt's Avatar
Hmm not sure actually, might work. And I spilled some of that blue crap on me today doing my preflight. Stupid wind.
Old 03-06-2007, 12:55 PM
Quick1998Z28's Avatar
Thanks, jason
you do realize that higher octane does not mean more HP. You want an insta-speed chemical additive, get nitrous. Running leaded gas in your car will wreck your O2 sensors, making your car run worse, and "cheap" it's still double the price of 93 which is around $2.30 a gallon. Chances are you will also have way too much unburned fuel coming out the tail pipe, which means the computer will think you are urnning rich, and the car will run like ***
Old 03-06-2007, 01:00 PM
ROCNDAV's Avatar
It will ruin your O2 sensors and plug up your cats. I used to run it in my IROC for the short term that I ran it without cats. It didnt make my car run like ***, but I never did any before and after dyno testing either. Is it really more expensive than 93 octane? Back in the 80's it was cheaper (and untaxed) IIRC.
Old 03-06-2007, 01:52 PM
darom's Avatar
Off topic: 91 octane in CA is over $3/gallon. How the hell do they explain hig gas prices now? Beginning of the spring?
Av-gas at the local airport is over $6/gallon. The only benefit of running leaded high octane av-gas, of course, is if you have a high compression engine (used to have 11:1 on my 67 with cast iron heads). But mine didn't have any oxygen sensors nor cats to plug up.
I can buy some gas from you (if you have it cheap) to put in my 67 (I will bump the ignition timing more). :-)
Old 03-06-2007, 04:12 PM
2000badbird's Avatar
Yes it will destroy ho2's and cats, In my s-10 i have a 11.5 to 1 355 We put 458hp and 485ftlbs on 93. We filled up the fuel cell on vp 112 we added +3 of timing and made 9 more hp than on 93 so there will be some sort of gain. Thats with no carb adjustments. Now with that bein said this is a low tech old school small block no pcm, knock sensors, or ho2s or cats so it would take an exprienced tuner to make the adjustments with our late model efi engines to see the power gains adding timing and possibly adding more fuel while keeping th a/f in check. So in a nutshell its not a practical way of making more power without making tuning adjustments .
Old 03-06-2007, 04:25 PM
olaferickson's Avatar
There is a gas station down the street from me in Brockton Ma. that has 101 octane race gas for $7.99 a gallon. Is there any point in using that? I know I have to run at least 93 to keep the knock sensors happy but is 101 any better?
Old 03-06-2007, 04:27 PM
MM2000Z's Avatar
i also can get 100LL from work...my ? is can i mix it with 93 and be safe...or better yet mix it half and half with 87 and bump the octane up to around 93 so it wont ping? I always wondered that..I dump it in my plow truck whenever i get a chance though, Usually mixing it half/half with 87.
Old 03-07-2007, 06:53 PM
BriancWS6's Avatar
So many people have a mis-understanding of what higher octane fuel does. The higher the octane is the more resistant to pre-ignition it is, or the slower its burns. If your not getting detonation with 91, or 93, then you won't see any benefit from running a higher octane fuel. The most power is made with the lowest octane that doesnt give you detonation. Leaded fuel kills your O2s in a hurry, so if you have an application that requires higher than 93 pump gas, then find some unleaded fuel to run.
Old 03-07-2007, 10:28 PM
styoung's Avatar
i have heard somewhere not sure if it true or not but avation fuel has different aditives in it, and that it isnt good for your car. the aditives are for the alitude its used, thats why at take off the mixture in small single engine planes is very rich, but than again there is a home built plane that uses a ford model A engine or a corvair engine in it, thats all i know, or i think i know if that makes any sence
Old 03-08-2007, 08:59 AM
ICRAZY6's Avatar
Yes there are aditives in aviation grade fuels. Now you can run aviation fuel in diesal vehicals. But JP-8 or Jet-A's not going to work well in you car.
Old 03-08-2007, 11:38 AM
Pro52R's Avatar
High Ocatne fuel is good when you have raised compression...to keep from detonation.
Also w/ higher ocatane fuel you can turn up the boost on a boosted application and make better numbers...IE..less detonation
Thats the nice thing about diesel..theres one grade that can makes all sorts of crazy power
Old 03-08-2007, 01:34 PM
DwayneZ28's Avatar
i tried it in my old LT1 car.... could not tell any difference.
Old 03-08-2007, 11:15 PM
greysteel_M6's Avatar
Unless your running a cat-less system stay the f-away from leaded gas.
Old 03-08-2007, 11:25 PM
crazboy99's Avatar
i know JP-8 is like diesel...we put it in things that require diesel at work...if that was the case with the 100LL it wont work with a gasoline powered engine...id test it out on something that is cheaper...like a lawnmower or something before you put it in your car...better to screw up a $200 engine then one that costs a couple thousand...me personally wouldnt do it...if you want race gas...get race gas
Old 03-09-2007, 08:15 AM
ICRAZY6's Avatar
Funny thing is on our Chinook Helicopters we can run gas if we had to. It would lack performance but we would still be able to fly them. There would also be a huge inspection once we landed and would have to drop the fuel cells for new ones and replace other parts of the fuel system.
Old 03-10-2007, 12:50 PM
Big_D's Avatar
just do it! not too many times.. itll be fun.. i promise
Old 03-10-2007, 09:00 PM
tx77015ls1's Avatar
a turbine engine can run on almost any combustible liquid, i bet the lead would leave deposits on the inside of the engine
Quick Reply: Aviation gas (100LL) in my 2000 Z28
