Plugs&Wires
Plugs&Wires
Well, I have a choice. Autolite Fine-wire or ACDelco Iridium. Which one?
Also, the wires I have available are Autolite Professional series or ACDelco OEM ($100 difference).
What should I do?
What should I do?
Well, I pulled a plug/plug wire and here is what I found
Perfect plug, sharp wire and clean arc-patch on arm. Perfect looking A/F as well. I checked gap and got .057 but did not wedge it in there hard as I am freaked about hurting the fine-wire or scratching the coating or whatever. I bet it was .060 dead on, had I measured it "tight".
OHM'ed out the wire and got 270-OHM. For comparis on I OHM'ed out my roommate's 2005 Impala and got 2800-OHM (makes sense since wire is 10X as long basically. Either way, looks too good to spend $100+ on any way you slice it.
LS1Tech Administrator
Received 1,468 Likes
Stock wires are fine. No need for anything fancy. I use the NGK TR55 plugs right now, but I think I'll try the AC Delco Iridiums next time.....
