Anyone else have problems with turn signal sockets corroding?
My front two turn signal/parking lamp sockets are in pretty rough shape (corroded) and I was wondering if anyone else has delt with this? I called the dealership and they are charging $65 for the socket and I have to solder it in to the existing wires. So basically it will cost me about $130.... that seems kinda steep to me. Do you guys know of anywhere else to pick them up for a little cheaper? Maybe Ebay? I looked but couldn't find anything. Thanks!
LS1Tech Administrator
Received 1,483 Likes
You aren't alone.
I've read numerous threads about this in the General Maintenance section over time. It's never happened to me, but then again my F-bodies never see bad weather.
You might try looking in the Classifieds section, maybe someone is parting out a car without front-end damage and will sell you the sockets for cheap.
yeah, I plan on doing most of the preventative things once I get them replaced, but as for right now, they're beyond repair. I'm to the point where i need new ones. I'm just looking for them as cheap as possible. $130 is just flat out highway robbery and I really don't want to choke that one down.
I would clean off the corrosion myself. There are several methods available; wire brush, wet-r-dry sandpaper, etc. After it is all cleaned and working correctly again, put a rust preventative coating on it, as suggested in posts above. These parts are not visible from the outside, all you need to do is insure a good electrical connection.
And I agree, the dealer is attempting to have intercourse with you without using vaseline.
