General LSX Automobile Discussion Non-technical LSX related topics.
2002 T/A ws6 will not crank
Old 04-17-2007, 02:51 PM
2002pontiact/aws6's Avatar
Question 2002 T/A ws6 will not crank
I have a 2002 t/a ws6 package and the car will not crank. It has a good battery and good starter. When i turn the ignition to crank it will do nothin. Need to know if it is n the security system and if so how do i rewset it or if there is a sensor gone bad.
Old 04-17-2007, 03:00 PM
staringback05's Avatar
could be the vats module.....you sure its not a lose battery cable or something?
Old 04-17-2007, 03:35 PM
Shinigami2x4's Avatar
Did you check the starter - my camaro had the same syptoms
Old 04-17-2007, 03:37 PM
no loose battery cable. I can bypass starter relay and hotwire it and it turns over just fine
Old 04-17-2007, 03:45 PM
WS6.Jay's Avatar
Does your SECURITY light come on and stay on? It may turn off while you are cranking the key but it should come right back on after you leave the key in the ON position.
Old 04-17-2007, 03:48 PM
no security light does not come on. Only if i set the alarm does it come on.
Old 04-17-2007, 03:49 PM
what is a passlock sensor?
Old 04-17-2007, 03:50 PM
someone told me that is bad and has to go to the dealer to be changed and alarm system to be reprogrammed.
Old 04-17-2007, 03:58 PM
WS6.Jay's Avatar
I dont mean the red light on the dash, I mean the actual light on the gauge cluster that reads SECURITY. If it does, try a VATS relearn:
To do that you need to turn on the key and try to start it then leave the key on for 600 seconds. Then, turn off the key and repeat 3 times.
If this doesn't do it, try your spare key. It could be the VATS system causing this, somewhat common. You can buy a VATS bypass like what people use on aftermarket alarms. Do a search for vats bypass.
Old 04-17-2007, 05:09 PM
Why didnt you just say leave it in for 10 minutes?
Old 04-17-2007, 07:13 PM
WS6.Jay's Avatar
Old 04-17-2007, 07:22 PM
Sorry i didnt mean for that to come out sarcastic like..
Old 04-18-2007, 01:14 AM
Disturbed Bird's Avatar
same thing happens to me try pushing all the relays and fuses down in the engine bay.
Old 04-18-2007, 01:28 AM
Hoss Ghoul's Avatar
Did you try checking/replacing the relay then?
Old 04-18-2007, 04:48 PM
changed relay and no fixee problem
Old 04-18-2007, 04:49 PM
car has been towed to the dealer now
Old 04-18-2007, 04:51 PM
anyone want to help me pay for it now.LOL gonna cost a bunch of $$$$$$$$$$$$$$$$$$$ I bet.
Old 04-21-2007, 03:10 AM
iverson387's Avatar
let me know what happens with this im having the same problem right now with no security light and if i jump the starter it works too. its gotta be something stupid withthe alarm or something
