shifter hits console!!! - LS1TECH
General LSX Automobile Discussion Non-technical LSX related topics.
Thread Tools Search this Thread
Old 04-24-2007, 11:37 PM   #1
razorclaw99's Avatar
Default shifter hits console!!!
hey..i bought the ws6 store short throw and it hits the console badly on 2,4,6...WHY!!! i did everything fine...then i put the stock shifter on and 2 hits it too but lightly..wtf yo but yet a generic ebay short throw ive been using didnt hit anything but i only replaced it cuz it made my gear box very gay..i kept throwing it into 1st instead of 3rd which is why i got the ws6 store one and it hits badly the console...what do i do..the console is on correctly.
razorclaw99 is offline   Reply With Quote
Old 04-24-2007, 11:40 PM   #2
Revelation Z28's Avatar
i have the stick and it doesnt hit. i can stick my pinky in between them.
do you have the leather ****? because the tail on it is what makes contact. i have the 8 ball looking stock ****.
Revelation Z28 is offline   Reply With Quote
Old 04-24-2007, 11:42 PM   #3
i took the leather off (yes i have leather) and its BARELY fine..like it works..then i took the console off and it was fine..so i mean its the stick that barely touches it..
Old 04-25-2007, 01:43 AM   #4
SweeTbone's Avatar
Most of the short sticks have a problem hitting if you DO NOT have a factory Hurst shifter. Many people have had issues if you put one on a stock non-Hurst shifter. Trim up the console or try adjusting it perhaps?
SweeTbone is offline   Reply With Quote
Old 04-25-2007, 01:50 AM   #5
01FormulaTA's Avatar
short sticks will only work w/ the factory hurst or other aftermarket shifter, not with the stock crappy GM shifter
01FormulaTA is offline   Reply With Quote
Old 04-25-2007, 01:51 AM   #6
i have the non hurst and its fine for me. maybe i just got lucky.
Old 04-25-2007, 02:34 AM   #7
Quote:
dude what r u talking about? factory= gm
i put the ws6 store shifter on the stock shifter (the base)..and it hits the 2,4,6 gears bad. i dont see what you r saying. I ended up putting my stock stock shifter back on (the long one) and its fine.. 2nd gear barely touches..
Old 04-25-2007, 03:05 AM   #8
Kage's Avatar
Cool
The one you have does it look like Lou's stick, pic on the right?
You just might need a short stick with the bend toward the driver side.
I have a Pro-5.0 stick that should fix the prob, pic on the left.
Cut to 6.5" brand new never used. Let me know.
Kage is offline   Reply With Quote
Old 04-25-2007, 06:30 AM   #9
Ntimid8r7's Avatar
Quote:
Factory installed HURST, is what he was talking about...
Ntimid8r7 is offline   Reply With Quote
Old 04-25-2007, 06:36 AM   #10
01FbTaWs6's Avatar
i have the factory installed hurst, with the ws6store stick, and its great, doesnt hit anything!
01FbTaWs6 is offline   Reply With Quote
Old 04-25-2007, 08:21 AM   #11
ZFan88's Avatar
I have the UMI short stick on the non-Hurst base. It hits the console if I shift hard. I'm saving up to buy a new shifter so I won't have that problem. The factory one is way too sloppy
ZFan88 is offline   Reply With Quote
Old 04-25-2007, 09:59 AM   #12
5.7 Reasons's Avatar
I had the same problem, and I don't have a Hurst shifter. So I took the stick back off, placed it in a vise and proceeded to bend it with a mallet. The stick is bent ever so slightly, just enough where the shifter won't hit the center console. I've driven about 4k miles with this setup and never had a problem since.
If you don't want to do this, you can always contact the WS6 Store and return it.
5.7 Reasons is offline   Reply With Quote
Old 04-25-2007, 11:21 AM   #13
TLUZLS1's Avatar
What he said...
TLUZLS1 is offline   Reply With Quote
Old 04-25-2007, 12:15 PM   #14
Kage's Avatar
Cool
Bull ****!!!!!!!!!
If he would have gotten Lou's short stick we wouldn't be discussing this right now.
Old 04-25-2007, 02:47 PM   #15
Check your trans mount.
taintedmeat is offline   Reply With Quote
Old 04-25-2007, 03:11 PM   #16
67rsss's Avatar
Is this the shift handle they are talking about? It came with our LS1/T56 form an 02 WS6. It has a bend in it that I assume is to clear the rear of the console. We are not going to use it, way to short for the 67.
67rsss is offline   Reply With Quote
Old 04-27-2007, 01:42 PM   #17
Nautilus's Avatar
I just bought a used Z28... I noticed it had the same problem. I took it apart and found a lou's short stick on the factory shiter. Who ever istalled it bolted it up with the bend to the rear. I simply unboted the short stick, turned it around and bolted it back on... Problem solved.
Nautilus is offline   Reply With Quote
Old 04-27-2007, 01:52 PM   #18
FNQUIKWS6's Avatar
I thought the bend was supposed to go towards the driver?
FNQUIKWS6 is offline   Reply With Quote
Old 04-27-2007, 01:59 PM   #19
Nautilus's Avatar
Quote:
I would have thought the same thing if I hadn't seen it... With the bend toward the driver on the stock GM shifter... It would almost not go into 2,4 & 6, actually it had worn off the black paint on the short stick from hitting the console. And in 1,3 & 5 it was in roughly what would be the middle position. I turned the bend in the oposite direction and the position in all the gears is perfect, not too far forward and not too far back.
Related Topics
Thread Thread Starter Forum Replies Last Post
who has a ws6store short stick? mediocrels1 New LS1 Owners - Newbie Tech 19 07-28-2013 11:59 PM
removong console to get to 6 speed shifter trans_am_2000 General LSX Automobile Discussion 8 07-10-2012 07:15 PM
Shifter question tirufunky Manual Transmission 4 11-17-2009 11:14 PM
Knob on WS6Store short stick newton Manual Transmission 14 01-30-2008 07:17 PM
What Shifter do I have stock? KuruptWS6spd Manual Transmission 7 09-10-2007 12:12 PM
Tags
2nd, 50, camaro, console, gear, handle, hit, hits, hurst, ls1, lt1, pro, shifter, short, stick, throw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
