Rev limiter questions
Do ls1 rev limiters really govern by limiting fuel? Also if you drive an auto and let it shift on its own will it ever hit the rev limiter? Reason i ask is because im soon to be running a dry shot and don't want to touch the governor while spraying.
LS1Tech Administrator
Received 1,489 Likes
A properly shifting auto should never hit the rev limiter. If it is, either the shift points have been modified, the tire size is wrong, or the trans is sliping due to internal wear or improper fluid level.
Originally Posted by BriancWS6
I agree with everything except the tire size. It wouldnt have anything to do with it. I have 35in tires on my 00 ecsb z-71, and at wot, it's never hit the limiter. Yes, the speedo will read lower than your actually going, but that's all it would do.
