polished slp loudmouth and cut out!!
that seems like a waste of money i doubt u gain much if any power loud mouth is already straight through but it looks good though
I know what a cut ou is and...But never knew the answer to the following question. Does the ECU automatically adjust to te free flowing air? To my understanding, there should have to be some adjustements to the spark or somthing wth the fuel, as there it's free flowing when the cutot is open.
Sorry for the novice question.
In addition to my previous question, to my understanding the car would make more power with a cutout behind each header vs one cutot in the y-pipe (my guess is around 10hp and 8lb of tourque). If someone is already putting on a cutout, setting it up one behind each header will be louder, but it's not like one cutout is much quieter.
So if someone can explain to me the logic of why people only put on one cutout, I'de appreciate it.
Thanks
Thanks
You actually loose a few hp if the cutout is right after the header. You loose some of the collective merging from the setup if done that way. The best bet is after the Y pipe.
Is this because theres a better scavenging effect if placed in the y-pipe?
(Not sure if scavenging is the correct word.)
