General LSX Automobile Discussion Non-technical LSX related topics.
Is a dyno tune worth the money?
Old 08-29-2007, 12:23 PM
Provie's Avatar
Default Is a dyno tune worth the money?
I was thinking about going and getting my car dyno'd the other day just get get a baseline number. Then I thought, while i'm there, might as well just have it tuned.
What I'm basically asking is, Is it worth spending money for a dyno tune?
Also, I was wondering what kind of abuse your car would go through (if any) when they dyno it and/or possibly tune it. Do they go WOT on the dyno?
My car that would be tuned is a 98 Z28 (6 speed).. Has intake and exhaust upgrades. Pretty much stock but I would still like to see where I'm at though.
Old 08-29-2007, 12:52 PM
SShawn's Avatar
a dynotune is worth every penny, especially if you have mods. and yes the car goes in WOT in 4th gear from 3k to limiter. where are you located?
Old 08-29-2007, 12:58 PM
stevegrizzle's Avatar
Not necessarily, you can do a wideband 02 street tune w/o a dyno. You won't have any numbers to judge from except the track tho.
Old 08-29-2007, 12:59 PM
EspaceF1Fan's Avatar
..Here is what I tell people.."How fast do you want to spend?"
Old 08-29-2007, 02:58 PM
Provie's Avatar
Very far away from NY. Wish I could ship it to you guys at New Era Performance to have it worked on though. I've herd a lot of good things about you on LS1Tech. Maybe when I have it stroked in a few years i'll ship it all the way over there.
From the sounds of it though, It seems like you guys are the best of the best.
I got another question for you.. How much more horsepower do you typically get from a dyno tune?
Old 08-29-2007, 04:02 PM
waldershrek's Avatar
I wouldn't do it until you get some mods under your belt that require tuning (Stall, headers, etc...)
Old 08-29-2007, 04:17 PM
ULTIMATEORANGESS's Avatar
if its not to expensive and youre not planning on any future mods that will effect your AFR then id have it tuned.
Old 08-29-2007, 05:53 PM
1999Transamman's Avatar
If you have done some bigger mods, then its worth it. I finished my longtubes and intake and the car wasnt running as good as it could, the shift points werent where they needed to be, so I was constantly hitting the rev limiter due to the 3600 converter, got it dyno tuned and the car is a whole new animal. It was definitly worth it in my case.
Old 08-29-2007, 06:14 PM
PSR
PSR's Avatar
Well said I agree 1000000000%
Old 08-29-2007, 06:58 PM
1meantransam's Avatar
mine runs like hell and i have full bolt ons and then some... i need a tune and i know it will be money well spent..
Old 08-29-2007, 07:05 PM
^^^Well if you have the mods listed there and have not had a tune I'd get one ASAP! Especially with that stall and the headers.
Old 08-29-2007, 08:06 PM
SShawn's Avatar
dynotunes can get you a wide array of numbers, for a bolt on car ide say between 5-10 RWHP
we gained 240 once with a procharged car, the tune it came in with was absolutely terrible, and the customer was lucky his motor wasnt trash. although thats a very unusuall situation. thereare dfinately good gains thought dyno tuning.
Old 09-05-2007, 12:21 AM
180ls1's Avatar
i know of a guy in the san tiego area that picked up 25 horsepower with a dyno tune his car is bone stock
Old 09-05-2007, 02:57 AM
01Z28M6's Avatar
Thanks for an honest answer as many people watch these threads wondering if they should spend up to $500 on these tunes. As you say, a huge advantage can be had for cars with power adders. Conversely, only very small numbers may be the result with some simple bolt on engines. Personally I hesitate to take my h/c car to a dyno for tuning. I'd be depressed to see $500 / 5 hp. That's why I bought a wideband and tuner that can adjust fuel, injector slope, PE and timing. But I'm still here to
Old 09-05-2007, 03:10 AM
JTelesone's Avatar
even if you dont get the tune, i put mine on there stock just to get a baseline and check out a/f. If you bought your car used like me it can tell alof about the car if the motor is running well. And alot of people get tuned with mods but regret not having a baseling to compare to. I think a tune is always worth the money
Old 09-05-2007, 08:36 AM
WADDISME's Avatar
The guy that tuned mine had a stock C6 Z06 on the dyno before me. He went from 441 rwhp to 464 rwhp. I think he only charged like $250(?), not a bad deal.
Old 09-06-2007, 11:08 PM
Mike @ New Era's Avatar
We generally charge around $300 flat rate for dyno time and tuning , I have gotten 30-40 rwhp tuning bolt on cars , but this only happens usually a couple of times a year and is usually because the car has some issues that I take care of along with the tuning that show up with the logs . But generally a bolt on car with no issues you will get 5-10 rwhp with a tune . Another benefit you generally get from having the car will be better consistancy of performance as well which is a huge plus for bracket racers .
Mike
Old 09-07-2007, 12:56 AM
SShawn's Avatar
H/C car i would definately get tuned, saftey purposes and there is still more power to be had.
Old 09-07-2007, 02:15 AM
Nimitz87's Avatar
most tuners charge about 1/2 the price for any other tuning...
my tuner charges $500 for a full dyno/street tune takes about 5-6 hours.
and then $250 for anything else at any time if i change something...
another one charges $300 and then $150...
so i say its worth it anytime.
Chad
Old 09-07-2007, 09:38 AM
keliente's Avatar
I'm a bit biased but yes I think it's worth the money. A full dyno/street tune really maximizes your car at any step of the way, stock, bolt-ons, or fully modded...makes it a lot more enjoyable in my opinion. Plus it's not just the peak power that matters, you get a lot more down low too, and that's where you really notice it.
Very few dyno tuners charge you the same thing every time...so even though you may pay $300-$500 for your first tune, usually they cut you a break when you put it on again to have it retuned for other mods.
Quick Reply: Is a dyno tune worth the money?
