Seized Front Caliper Slides - LS1TECH
General LSX Automobile Discussion Non-technical LSX related topics.
Thread Tools Search this Thread
Old 03-17-2008, 07:41 AM   #1
BadGTho's Avatar
Default Seized Front Caliper Slides
so i went to replace front pads with lower dust pads. upon reinstalling the calipers, i realized that the lower caliper slide on both front brackets were seized. when i tried to extract the old slides, they just broke.
anyway.... every parts store sells rear brackets separate, but only napa had front brackets. they ONLY came as loaded calipers with brackets.
long story short, i did both calipers up front and brackets.
anyone experience this?
BadGTho is offline   Reply With Quote
Old 03-17-2008, 09:10 AM   #2
All f-bodies experience this, thats why the rotors warp. When I changed my pads and rotors all the slides were dry, and stuck. I bought all new OEM pins from the dealer and used some anti seize on them and that took care of it.
wrb07sti is offline   Reply With Quote
Old 03-17-2008, 09:13 AM   #3
jmm98LS1's Avatar
Same thing happened to me, I had a machine shop get the stuck pins out so I could save the brackets. New pins with lots of grease & new rubber boots, no more warped rotors.
jmm98LS1 is online now   Reply With Quote
Old 03-17-2008, 09:50 AM   #4
BadGTho's Avatar
lol.. good to know it's not just me. GM sucks.
my Sten had a similar issue with the rear calipers.. common on all GM trucks with rear disc... but the slides on the T/A were totally fused... not able to be freed up.
rather than go thru the effort to drill... i went with the new brackets, complete with new slides and boots.... for the money, it seemed like the best option.... for a total of $130 i got new calipers, brackets & slides for the front.. they even came with new pads, which i did not use.
how likely is it that my rears will suffer the same fate?
Old 03-17-2008, 01:03 PM   #5
Quote:
Very likely, as all of mine were frozen.
Old 03-17-2008, 01:14 PM   #6
ae13291's Avatar
i never had this issue! maybe its something everybody is doing wrong? i have always greased the pins and antisiezed all the bolts on the brake assembly
ae13291 is offline   Reply With Quote
Old 03-17-2008, 01:15 PM   #7
BadGTho's Avatar
Quote:
lol.. me too. it's how i was taught, but seeing as the previous owner did the brakes last, it's possible.
i can tell you that my Sten had original brakes, and the issue was still present.
i live in new england. never seize is a way of life.
Old 03-17-2008, 01:19 PM   #8
ae13291's Avatar
i used the white purpose lithium grease! that works perfect since it waters out when it sees heat so the whole pin is lubercated inside the boot, and i used aircraft c5 high temp copper antiseize on all bolts and pad sliding clips
Old 03-17-2008, 01:27 PM   #9
slt200mph's Avatar
153,000+ miles on the orginal calipers..no problems with them...I always use the correct lube when I do brake jobs(about every 50K).
slt200mph is offline   Reply With Quote
Old 03-17-2008, 01:28 PM   #10
ae13291's Avatar
yea same here, good to hear no problems after using lube! lube it or loose it
Old 03-17-2008, 03:30 PM   #11
Rushin's Avatar
The previous owner never lubed them up. I had to knock on a 16 mm socket and use an impact to get the thing out. Socket still good too.
Rushin is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Anything special to remove rear rotors? Jorgens Suspension & Brakes 17 06-06-2015 06:23 PM
Ls1 Front Calipers Left to Right Difference Meen95z Suspension & Brakes 10 03-24-2015 08:52 AM
Rear Brake Caliper Mount-? MTs94Z Suspension & Brakes 3 03-13-2015 01:41 PM
WTB: Front Driver side caliper bracket David_94Bird Parts Wanted 0 07-06-2014 09:43 PM
looking for tutorial for doing rear brakes blue09rocket Suspension & Brakes 9 03-15-2014 08:14 AM
Tags
2003, 99, caliper, calipers, camaro, f250, font, front, pin, pins, rusted, seized, siezed, slide, slides
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
