General LSX Automobile Discussion Non-technical LSX related topics.
what should i do first?
Old 05-11-2008, 08:45 PM
94TRANS's Avatar
Default what should i do first?
ok so i have a ls6 intake and P&P TB waiting to go on but was wondering which of the following should i get next?
ported MAF ends
160 degree thermostat
underdrive pully
MSD wires NGK plugs
(all at same time)
OR:
TSP true dual set up?
then after these im getting gears.
what do yall think? thanks
-Kris
Old 05-11-2008, 09:24 PM
98Z28MASS's Avatar
Get the duals. The pulley wont help much until you get a cam in there and the rest of the mods arent going to add a ton of hp either. The duals should add 5+ rwhp and the sound alone will make you glad you got them. Plus and wires are a good idea too but I would go with the duals and piece the other mods together as you go.
Old 05-11-2008, 09:29 PM
blacksskid07's Avatar
go to your local speed shop and get some true duals!!
just do some msd wires and tr55 plugs very cheap
Old 05-11-2008, 09:32 PM
miamifan3413's Avatar
No need to mess with this:
ported MAF ends= makes it a bitch to tune
160 degree thermostat= lower temps cause more carbon build up to occur
Get the dual set up if loud is what you want, and definately get gears...A4 3.73's
Old 05-11-2008, 09:36 PM
94TRANS's Avatar
^ok thanks for the info so would just a new better MAF be better to get.
i think i will get the duals cause i love the sound of a mean car.
Old 05-12-2008, 10:02 AM
98Z28MASS's Avatar
No need to update the MAF unless your a really high HP car as if you dont get it tuned for the larger MAF it can run like crap. If anything do the plugs and wires with the duals if you have the cash for both. Then gears as stated above.
Old 05-12-2008, 10:06 AM
z28_YOU_HO's Avatar
true duals a a Lid
Old 05-12-2008, 10:13 AM
mycamaroSS's Avatar
true duals fo sho.....
Old 05-12-2008, 02:48 PM
94TRANS's Avatar
alright thanks, i guess im going to get the true duals and plugs and wires!
