General LSX Automobile Discussion Non-technical LSX related topics.
LSX in a 99 SS???
Old 06-07-2008, 01:23 PM
jc99ls1ss's Avatar
Default LSX in a 99 SS???
What all can I reuse off the ls1 onto an lsx and what will be required to keep stock computer and wiring, etc? trying to figure out a starting point.
Old 06-07-2008, 02:21 PM
Mattism78's Avatar
What is a LSX? I know it's often referred to as X being any of the LS variants. X being 1, 2, 3, etc.
Old 06-07-2008, 02:25 PM
99NMB's Avatar
I think he is talking about the lsx block.
Old 06-07-2008, 02:31 PM
Mattism78's Avatar
I just did some searching and found some info on the block. Quite impressive. Guess using the phrasing LSX powered vehicles is no longer valid.
Old 06-07-2008, 02:35 PM
Justin00SS's Avatar
Why would you want to use anything less than LS7 parts?
budget?
Old 06-07-2008, 04:29 PM
jc99ls1ss's Avatar
More than likely would use ls7 or aftermarket parts for it. But I am not sure if it has all the sensor mounts(knock sensor and such) and if there is a 24 t reluctor wheel for an ls7 crank and so on. Would my a/c and other acces bolt up without modification and so on is what I am looking into. Wondering if someone has put one in an f body and what kind of problems or changes they had to make.
Old 06-07-2008, 04:58 PM
Justin00SS's Avatar
painless has a kit for the electrical as spect.
As far as mechanical/design it will just swap in with little to no modification. I think you would need an LS2 flywheel and ls7/2 clutch if you are an m6 though.
