General LSX Automobile Discussion Non-technical LSX related topics.
Want to take out the lt1 and put ls1 in it..
Old 06-07-2008, 10:39 PM
ATAY383's Avatar
Question Want to take out the lt1 and put ls1 in it..
I always want a ls1 car but cant find one in good shape or they want to much so im thinking about putting a ls1 in it. and has anyone done this before if so what do i all need to put the ls1 in a lt1 camaro. Thanks
Ashton
Old 06-13-2008, 06:09 PM
ATAY383's Avatar
I know that this thread isnt in the right place and i know there is someone out there that has done this so if you guys could help me out i would be thankful for you guys helping.
Old 06-13-2008, 06:23 PM
That_guy's Avatar
go to the hybrid section and you will get a better response there. but from what i hear its a straight drop in but your going to need a ,wireing<--spell check) harness for the ls1 or something like that.
Old 06-13-2008, 06:36 PM
Revelation Z28's Avatar
try to find a dropout with PCM and harness. all you would need to do is drop your engine with the K member and put the LS1 with its K member in.
Old 06-13-2008, 07:00 PM
kw's01z28's Avatar
really i would just build up the lt1 thats a lot of trouble considering the power diff is not very much unless you just like to say you did it which is cool but yeah just my opinion lt1's are also great engines(-the opti spark) and cheaper parts.
Old 06-13-2008, 07:58 PM
ATAY383's Avatar
i like the lt1 but i hate the dam opti spark they give me so much problems other than that my freinds is selling me a lt1 and a transmission but i really dont trust the guy though cause i have a 383 in it and he says its fubard but then a guy looked at it and said there is nothing wrong with this car all it needs is a tranny and a optispark. so i dont know who to trust anymore iv got fubard over alote by my friends and if i have to buy a new motor i want to do a newer motor or can you buy a lt1 383 with a tranny with it all i have is a thousand dollars to spend.
Old 06-16-2008, 07:10 AM
Afflicted's Avatar
If you keep the LT1 make the investment of the MSD opti for $500 so you dont have to worry about it anymore. As for the swap...do a search I researched it not long ago and found loads of info on here regarding all the needed parts.
Old 06-16-2008, 07:39 AM
406malibu's Avatar
You wont get a ls1 swap for that much, you'd be looking at 3k minimum (seen a few done for 2500, but got really lucky), if you did all the work your self. also your posts are REALLY hard to read. I know I have terrible grammar, but damn.
Old 06-16-2008, 10:27 AM
Gaunt's Avatar
Ehh, I would keep your engine and mod the **** out of it more.
Old 06-16-2008, 08:30 PM
Kingc8r's Avatar
I would pay the extra cash and geth the ls1. I would say it has a better aftermarket support. All my LT-1 buddies have problems, but it could just be there cars.
That being said you can make a LT1 based engine just as fast
Old 06-17-2008, 11:35 AM
RSbeast's Avatar
Why doesn't anyone just buy an LS1 and put LT1 body panels on it?
I still think the LT1 T/A's look waaaaaaay cleaner.
Old 06-17-2008, 11:57 AM
PowershifterNC's Avatar
go for the ls1...you'll be lighter and faster in the long run
Old 06-17-2008, 12:44 PM
Texfinn's Avatar
How much have you thought about spending on the LS1 car? If you can only spend a few grand, sure, the car might have some issues and/or 100K+ miles, but I think buying one and maybe fixing it up a bit is still going to cause you less hassles than doing the LT1 to LS1 swap.
Old 06-17-2008, 12:52 PM
NSSANE02's Avatar
I've seen LS1's with the harness go on this site for 1500-3K, if that and a k-member is all you need I would definately go that route.
Old 06-18-2008, 12:01 AM
BYE RICE's Avatar
If it's the opti you're concerned about,they make kits that retrofit LS1 style coil packs to LT1's.GMHTP used it on one of their project cars.
Anyway..I don't think it would really be worth it to ditch the LT1..
If you had an old worn out V6..then maybe so..Since you can pick them up so cheap & all that stuff gets replaced anyway.
An LT1 can be made to run really well..The one thing an LT1 guy can't do is exceed 393 (I think) cubic inches( most are 383's)...But good heads & effective power adders are plentiful & well sorted out.
Old 06-18-2008, 03:04 PM
chavez885's Avatar
If you only have 1k to spend, don't bother looking into doing an LSx swap. You'll need a k-member,PCM and wiring harness, may need diff trans parts to bolt up to the motor (i know m6 does), and you'll need the LS1 steering setup (can't think of the technical name).
Old 06-18-2008, 03:45 PM
Spiers's Avatar
I think it would be a big waste of money to swap an LS1 into an LT1 car, especially since you are on a budget. Either mod it more or sell it and buy an LS1 car. The optispark is NOT that big of a deal
