ls1 hates hot weather!
ive noticed that the car has all kinds of power when its cold . if its like 97 like it is now here in ga. it hates it! heat robs these ls1's bigtime!
The air up where I live is already pretty thin (3800+ft elevation), warm temperatures just destroy performance. I've seen LS1's run high 14's on hot days here...
cold is great for dyno numbers!
While yes cold autumn or spring mornings are best for track times.
The way I look at it.. The heat's slowing me down, but those Mustangs and cIviCkZ aren't doing any better.
When it's cold outside, I can't get traction, and when it's hot, I hook, but don't make quite as much power.
I don't know about yours but mine definitely runs a little hotter when its 90+ outside than when its a lot cooler out. This is going off a HPT scanner though and not the factory gauge which doesn't change much.
