Strong smell of gas from rear of car...
Old 10-15-2008, 12:34 PM
02RedWS6RamAir's Avatar
Default Strong smell of gas from rear of car...
My 95 Trans Am has a very strong smell of gasoline from the rear of the car. There are no visible signs of leaking anywhere. I've heard that the seal around the gas tank/fuel pump can go bad..... I'm dropping it off at a repair shop later in the week. I just though I would see what you guys thought.
Thanks.
Old 10-15-2008, 01:11 PM
2001NBMZ28's Avatar
Maybe it's just the evap canister or associated hoses. There's also a vent hose/filter back there that might be missing. Just a couple ideas.
Old 10-15-2008, 01:26 PM
Wouldn't it throw a code?
Old 10-15-2008, 02:02 PM
2001NBMZ28's Avatar
An evap canister purge valve circuit code (26) is the only one I'm aware of. I'd jack the car up and pull the LR tire and look around first before bringing it to a shop. http://shbox.com has diagrams of the '95 evap system and components. Good luck with it, hope it's something easy.
Old 10-15-2008, 02:55 PM
Thanks! Good info!
....When it comes to the luck I have it's never something easy!
BTW is the evap system something that is known to be problematic?
Old 10-15-2008, 03:49 PM
2001NBMZ28's Avatar
Don't know, but if the purge isn't working and/or the canister gets saturated you can get a fuel smell.
Old 10-15-2008, 04:16 PM
The guy I had bought the car from had left it in storage for about a year. I wonder if that made a difference........
Old 10-20-2008, 12:21 PM
dbuie's Avatar
My sister had the same symptoms ('97 Chevy Blazer) and she had no codes on her car. Turns out the whole top of her tank had rotted out. She even took it to several people to have it looked at and the third one actually took the time to crawl underneath her car. He placed his hand on top of the tank and there was no top, it was gone for the most part.
Old 10-20-2008, 03:34 PM
angel71rs's Avatar
My gas smell turned out to be a busted fuel tank vent valve. I think 98s are like LT1 years in how the gas venting is done. Thread:
https://ls1tech.com/forums/general-maintenance-repairs/895879-anyone-know-what-evap-system.html
Old 10-20-2008, 04:11 PM
98 WS6's Avatar
You don't have an aftermarket cam do you? I have one in my car, and lately now that it's getting cold out, I smell gas on cold startup. This is just from unused gas that's trying to be put in while the aftermarket cam goes around.
Quick Reply: Strong smell of gas from rear of car...
