Codes P0171, P0174, Cleaned MAF, Still On!
Old 10-25-2008, 09:26 AM
Tuffguy610's Avatar
Default Codes P0171, P0174, Cleaned MAF, Still On!
Hey guys,
It turned out that there was a leaking pcv hose, its fixed now. Thanks
Old 10-25-2008, 09:36 AM
2001NBMZ28's Avatar
Those codes say you're running lean on both banks. Most likely cause is a vacuum leak or PCV issue. www.gearchatter.com/viewtopic8886.php
Old 10-25-2008, 10:25 AM
Formula413's Avatar
Don't replace the O2s! They are telling you it's running lean, don't shoot the messenger. Check for vacuum leaks as stated. Start with the PCV line.
Old 10-25-2008, 12:53 PM
chase99's Avatar
have you tried spraying around intake o rings just a thought. common to leaks and lean codes.
Old 10-25-2008, 02:04 PM
Tuffguy610's Avatar
Chase, do you mean nitrous? Nah I haven't used any nitrous on this car. I have the printout from the gearchatter link already. I changed the PCV valve a year and a half ago. The funny thing is that I have been noticing a smell of gas when I take off from a stop. I know I'm not obviously running rich because of the codes set in the PCM and the car is actually running pretty efficient on gas now. Maybe the gas smell could indicate something?
Old 10-25-2008, 02:09 PM
Formula413's Avatar
He doesn't mean nitrous, he means spraying carb cleaner around these areas, that is how you find vacuum leaks. If you hear a change in idle speed when spraying a particular spot, there's your vacuum leak.
Old 10-25-2008, 02:13 PM
Tuffguy610's Avatar
Nah I didn't do that yet. I have heard of that trick. Its raining out today so maybe tomorrow I'll try that. I thought maybe he meant a wet shot of nitrous into the intake or something like that.
Old 10-25-2008, 03:14 PM
FiredUpZ28's Avatar
Still could be a MAF problem - maybe the heater element took a dump. MAFs work by heating up an element. As incoming air comes in, it cools the element, more air = cooler element. Then it takes a reading based on how many amps it takes to keep that element 200 degrees above ambient air temperature. This is all done super fast. So your MAF still could be going out.
Old 10-26-2008, 10:51 AM
Save the manuals!
wssix99's Avatar
Just curious - Have you changed your fuel filter?
Old 10-26-2008, 01:36 PM
Tuffguy610's Avatar
Yea, I changed it like 4,000 miles ago. Update: Did the intake spray test today with carb cleaner to see if it would raise the idle speed. It didn't. The light was still on when I left to go out for the day, I said the hell with it. To my delight, I was leaving my favorite pizza joint when I realized the SES light turned off! It does this sometimes, but I am thinking that maybe after cleaning the MAF it had enough clear drive cycles for it to clear the code. I had started and driven the car maybe 6-7 times since I cleaned the MAF. Anybody have any ideas for how many drive cycles it would take for that?
Old 10-26-2008, 03:40 PM
knightryda01's Avatar
this might be a dumb question, but what kinda gas are you running? I bought my car it was hittin codes and thought it was the 02. The guy had mentioned he was running regular gas in it because he never drove it.
After bout 2 tanks of premium light is off and has not came back on.
Old 10-26-2008, 04:55 PM
FiredUpZ28's Avatar
take it on the highway and do some driving. The tests have something to do with going 50 mph and decelerating to 30 or something like that. Don't quote me on that part.
Old 10-28-2008, 11:44 AM
Tuffguy610's Avatar
Running premium. 93 Octane.
Quick Reply: Codes P0171, P0174, Cleaned MAF, Still On!
