Oil pressure and Mobil1 5W30?
Old 11-02-2008, 10:42 PM
02RedWS6RamAir's Avatar
Default Oil pressure and Mobil1 5W30?
So my oil pressure seems low. (see other post) I have not gotten a chance to hook up a mechanical gauge.
Some guys seem to mention that Mobil 1 5W30 is a very thin oil. Especially on a motor with over 100k.
What do you guys think?
.......and what would be a better weight?
Old 11-02-2008, 10:54 PM
ae13291's Avatar
it depends what the motor has been through, for example i use 5w30 M1 and i have 88k but my oil pressure is always high. if u are going to step up go to 10w-30 and see how u like that if u still think its to low look for 10w-40. the 10-40 for sure should cure the problem
Old 11-02-2008, 10:57 PM
LS6427's Avatar
Pressure isn't what lubes the engine anyway, its the oil flow. If you're reading pressure, you are getting flow.
40 psi at cold start-up and 40 psi while cruising....is perfect, with Mobil 1 at that weight.
Old 11-02-2008, 10:58 PM
Sounds good! So maybe Mobil1 10w40 or something else?
Old 11-02-2008, 10:59 PM
LS6427's Avatar
Yeah, do that. 10/40 is better than 5/30 for sure.
Old 11-02-2008, 11:00 PM
ae13291's Avatar
try 10-40 man for sure that will do it, and do it asap! i would be worried as hell driving like that.
Old 11-02-2008, 11:02 PM
LS6427's Avatar
His oil pressure is perfect at cold start and at cruise. No worries. At idle after its warmed up, thats exactly the oil pressure he should have with 5w30 Mobil 1.
Old 11-02-2008, 11:03 PM
......going to try and get it done tomorrow.
I wish I would have known that the 5w30 is too thin!
Thanks for the advice!
Old 11-02-2008, 11:09 PM
LS6427's Avatar
It might help a little bit at idle after your warmed up, might not. Idle oil pressure isn't important though (unless its zero of course), under acceleration, cruising and cold start-up is when you need good pressure, and yours is perfect at 40 psi.
Old 11-03-2008, 12:46 AM
ae13291's Avatar
for your info i have like 50psi oil pressure at cold start with 5w30 M1
Old 11-03-2008, 01:56 AM
LS6427's Avatar
Thats about right, you have 10 psi more than he does. Cold start-up on LSx engines vary from 35-60 psi. I have right at 60 psi on cold start, but I use 20w50.
Old 11-03-2008, 10:34 AM
Cold start with mobil 1 5w30 was just slightly over 40. While driving around town, at roughly 1500 RPM gauge shows 35-38ish.
Getting the oil changed to 10w40 later today............
Old 11-03-2008, 10:57 AM
LS6427's Avatar
That is 100% perfect oil pressure readings.
You might see higher cold start up pressure, but cruising around pressure will probably be the same....WHICH IS ALREADY PERFECT!!!!!
Use reguklar oil, 20w50. You'll love it and so will your engine.
Old 11-03-2008, 11:53 AM
YellowToy/A's Avatar
Why you use Moble 1 I have no Idea. I bet you use a Fram filter too. Do a bit of looking and you will see that Moble 1 is living off hte rep from long ago. There are alot better oils. It is thin with poor protection for what you pay for.
Old 11-03-2008, 02:01 PM
Apparently Mobil1 5W30 is a little light for a higher millage LT1. I didn't know that. I did some checking and have now changed my opinion.........
Actually, I had a Mobil1 filter oil filter.
Old 11-03-2008, 02:17 PM
Tech Resident
ChocoTaco369's Avatar
I'd go 0W-40 or 5W-40 well before I went with a 10W-40. Winter is coming. You don't want a 10W oil in winter. Hell, I don't want a 10W ever. 0W's and 5W's provide lubrication to the motor faster during startup and protect better at cold temperatures.
Old 11-03-2008, 02:52 PM
temperatures.
My T/A will be in storage soon, so no winter driving for me.
Old 11-03-2008, 02:53 PM
LS6427's Avatar
Dude, what are you gonna put in there?
20w50, regular oil, right? 124K miles, thats what you want.
Old 11-03-2008, 03:22 PM
...just got it changed. I went with 10w40 and a K&N Oil Filter. Going to drive it to work tonight and see how it responds.
