Window motor going out?
I did search and no one described a problem like mine.
If I use the express down on the drivers window it goes down. On the way back up it stops and makes an overload type click about 4 times before it's up all the way.
Otherwise I can power it down until it's about 2" from bottom and power it closed 20 times and it never cuts out.
Should I just get a motor?
Ya, had that problem with my 93 cadillac, it would click cause the motor is going out, mines would work sometimes then it just completely stopped. Went to the junk yard and found a newer one, put it in and works perfect.
