Cruise control
Old 11-09-2008, 05:56 PM
ds98formula's Avatar
Default Cruise control
Hey guys and girls my cruise control just stopped working and I can not find a fuse for it or any thing to check. Any ideas on what to check to see why it stopped working. The rest of the multifuction switch works fine. Any help would be appreciated
Old 11-09-2008, 08:19 PM
the_merv's Avatar
The Fuse should be under the Hood or in the side of the Dash on the inside of the Door..
Old 11-09-2008, 10:17 PM
subhumanzz's Avatar
the fuse is under the hood.
Old 11-10-2008, 05:33 AM
((((((Administrator))))))
CRAGER's Avatar
I see you have an M6. If it's not the cruise control fuse check the switch on the clutch pedal, the one on the back side of the pedal. Make sure it's closed (compressed), when you press clutch it pops out turning cruise control off.
~ Craig
Old 11-12-2008, 11:53 PM
ozzman98's Avatar
i have the same problem. my fuse is good and hte switch is good. is there a vaccum line for the cruise that could be malfunctioning?? thanks
Old 11-13-2008, 08:16 AM
AFASTYZFR1's Avatar
Make sure your brake light are working.......thats what kept mine from working
Old 11-17-2008, 01:42 PM
Thanks for all the help I will try every thing when i get home.
Old 11-18-2008, 08:56 PM
1994z's Avatar
second the brake light. it will keep one from working..
Old 11-18-2008, 09:00 PM
samson_420's Avatar
Post back on what you find. . .
Old 11-18-2008, 10:06 PM
2000Hawk's Avatar
I have the same problem and its the clutch circuit switch on mine, just as crager mentioned. If that is the problem fix it ASAP, with mine not working not only does my cruise control not work, but i can turn on the car without pushing in the clutch. And thats pretty dangerous if you leave your car in gear and someone gets in not realizing it and turns on the car.
-Joel
Old 11-19-2008, 07:25 AM
samson_420's Avatar
I always remove the clutch start switch. But what do I know, I have a a4 now? . . .
Old 11-19-2008, 07:41 AM
the_merv's Avatar
That's why no one else drives my Car unless they have to..
Old 11-21-2008, 10:31 AM
99monguse's Avatar
Make sure the switch is adjusted properly. If it isn't fully depress then it won't work.
