Steering vibration, squeak, excessive brake dusting?
Old 11-09-2008, 08:13 PM
SparkyJJO's Avatar
Question Inner pad dragging on rotor, causing wheel drag, squeaking, and excessive dusting
updated (long overdue)
I have a problem with my front driver side brake.
About a year ago I replaced the rotors and pads. A little over a month ago I replaced the caliper.
I had the car up on a lift this weekend replacing my oil pan and changing my transmission fluid. While it was up I checked that front driver side wheel. It does not spin as freely as the passenger side. I checked the wear of the rotors and the inside of the driver side rotor is much more worn than the inside on the passenger side. Outside surface wear is the same on both driver and passenger.
It appears that something is causing the inner pad to continuously drag on the rotor. The slide pins were replaced when I did the caliper and they slide freely.
I would think that if there was a brake line issue, it wouldn't just be causing the inner pad to drag. Any idea what could cause this? Unfortunately I didn't have time to look into it more while the car was up on the lift and I'm not mechanically inclined enough to just start tearing into things *****-nilly without knowing exactly what I'm looking for.
Attached Thumbnails Steering vibration, squeak, excessive brake dusting?-1105081625-800x600-.jpg   Steering vibration, squeak, excessive brake dusting?-1105081626-800x600-.jpg
Last edited by SparkyJJO; 11-30-2008 at 07:37 PM. Reason: Updated with more info since first posting
Old 11-10-2008, 05:03 PM
SparkyJJO's Avatar
Anyone?
Old 11-10-2008, 05:12 PM
xRelapse13's Avatar
have you checked to see if the caliper is dragging?
Old 11-10-2008, 05:55 PM
SparkyJJO's Avatar
It shouldn't be, since I replaced it. When I had the car jacked up the wheel seemed to spin OK. I can jack up the car and check it again this weekend.
Old 11-10-2008, 11:02 PM
FiredUpZ28's Avatar
what kinda pads did you use. Are the pads evenly worn on the wheel (like the inner and outer pad should be worn the same).
Old 11-11-2008, 08:23 AM
SparkyJJO's Avatar
When I had the caliper off the pads looked worn the same amount. I want to say the pads are Evolution ceramic pads, not sure if the brand name is right though I'll have check.
Old 11-30-2008, 08:01 PM
SparkyJJO's Avatar
long overdue update... just had the car up on a lift and poked around the wheel. I updated the first post with what I've found.
