storage question
Old 02-05-2009, 06:35 PM
MTBSully's Avatar
Default storage question
What PSI do you guys keep your tires at during winter storage? Does it depend on the make and model tire or is it pretty standard? Mine is being stored on Grass and hasnt been moved in about a month or so
Input?
Old 02-05-2009, 07:42 PM
LS6427's Avatar
Go buy 4 jack stands and put it in the air. Thats whay everyone does that I know who lets their car sit for months at a time. Grass or not. Pressure won't matter than.
Old 02-05-2009, 08:20 PM
sman's Avatar
I was always told that when you store a car not to let the suspension hang loose, that the suspension is supposed to be at normal ride height, jack stands would be fine for the back if placed under the rear end, but im not sure what you would do for the front.
Old 02-05-2009, 08:54 PM
bLuE_DeViLz28's Avatar
id put 60 psi in the tire but if you go drive it, of course lower the tire pressure. on the inside of your door the should be a sticker which would tell you what to set them at but you need to overinflate your tires so you wont get flatspotted.
Old 02-05-2009, 09:06 PM
LS6427's Avatar
Thats what I mean, jack stands under the axles and spindles. Or whatever its called up front to set them under. There's a spot up front that keeps the suspension under normal weight.
Old 02-05-2009, 09:26 PM
sman's Avatar
Thats what I would do.
Old 02-06-2009, 10:53 PM
Formula413's Avatar
FYI: I have read that for drag radials or any competition tire they should actually be deflated to 1/2 normal operating pressure and removed from the vehicle if it will not be driven for extended periods, and they should not be exposed to sub-freezing temperatures.
