A/C Orifice Tube
Old 02-26-2009, 08:34 PM
SmokedOutZ28's Avatar
Default A/C Orifice Tube
I have converted most of my A/C system to a LS1 style except for the Evap, since I'm using my 93-97 Evap and the fittings are different the lines need to be cut and welded together I want to make sure there will be a Orifice tube somewhere in the system. Can someone tell me where it's located in the 98-02 system & the 93-97 System?
Old 02-26-2009, 09:28 PM
NBM-LS1's Avatar
Im pretty sure it is right next to the accumulator.
Old 02-26-2009, 09:34 PM
In the line? if so which one? and what year 98-02 or 93-97? lol
Old 03-01-2009, 05:14 PM
Bump, Anybody know?
Old 03-01-2009, 07:04 PM
NBM-LS1's Avatar
If you can wait till tomorrow morning when I can get to a computer with alldata I can tell you.
Old 03-01-2009, 07:26 PM
That would be great. I appreciate it!
Old 03-02-2009, 09:03 AM
NBM-LS1's Avatar
Well according to Alldata the orfice tube is located in the tube and fitting right on the inlet of the evap.
Its right there on the inlet line.
Old 03-02-2009, 09:13 AM
9000th01ss's Avatar
How do you plan on welding that aluminum tube? Usually any attempt at this results in failure.
The orifice tube goes in the liquid line at the location in the pic.
Old 03-02-2009, 09:29 AM
Thanks for the info guys, any idea on the 93-97 F-body? I don't plan to weld it I'm going to have it professionally done.
Old 03-02-2009, 10:48 AM
9000th01ss's Avatar
93-97 don't use an orifice tube.
As much of a pain in the *** it might be, I'd put the LS1 type evaporator in it.
I've done AC work for 16 years, started HVAC school in 1990. I've had access to the most modern aluminum/aluminum welding materials from hot welding to cold epoxies. To this day there is no effective permanent weld available for aluminum AC lines. If there was we'd be doing $120 repairs instead of $1800 replacements.
I have done my own custom automotive AC work as well.
The problem you have is adapting metric to SAE lines. Starting in the 1994 build date the refrigerant was switched to 134a and at the same time all the fittings were switched to metric.
I have taken hard aluminum lines and had rubber sections spliced into them so it would end up with an SAE fitting on one side and a metric on the other (crimped fittings, just like factory). I have also joined two aluminum lines with a flare union (NOT a crimp union) and is still working today, it's ugly but it's well hidden. I didn't even think it would work but it's going on six years now.
Old 03-02-2009, 11:14 AM
Yeah, I'm going to look into that option but with the cases being different I'm not sure if a LS evap will fit into my LT1 case. Another thought I had was to take the end off a LS evap and "mate" it to my LT evap so no welding would be needed and I can use all the fittings & lines from a LS car.
Quick Reply: A/C Orifice Tube
