How do you remove the pulley above the a/c tensioner?
Well I decided to fix my squekay pulley but I ran into a problem. The T-50 torx headed bolt stripped out like it was made out of tinfoil. All efforts to remove it have failed.
I was wondering how I remove the bracket that holds this pulley? The a/c tensioner came off with a simple turn of the wrench. The other pulley is the single most stubborn bolt I have ever seen. How can I get the bracket off? Where are the bolts that hold it on? Do I have to remove the air conditioner compressor? I can't find where the bolts are that hold this thing on.
Here is a picture of the pulley, circled in red.
Would I be better off just getting a reverse bit extractor and drilling it out while it's still on the car? Or can it be removed easily?
