Why my turn signals stay lit up on dash??
Old 04-11-2009, 04:13 AM
tnmotown's Avatar
Default Why my turn signals stay lit up on dash??
My left and right turn signals stay lit up when i use them. The green arrow on the gauges stays on and the lights from outside also stay lit up but dont flash. Also, when i turn on my hazards lights, the rear taillights flash but the front ones dont?
Is there something wrong with my front turn signal bulbs or socket? Or would it be a flasher problem? I looked underneath the steering wheel for the flasher but couldnt find it, just found the one for the hazards which i heard "clicking" when they were on. Any help would be appreciated guys, thanks!
Old 04-11-2009, 04:28 AM
cookba's Avatar
replace the bulbs
Old 04-11-2009, 04:35 AM
tnmotown's Avatar
Originally Posted by cookba
replace the bulbs
gotcha, i'll do that and report back to ya. thanks
Old 04-11-2009, 09:56 AM
bobbyd's Avatar
yea replace bulb also make sure theres no corrosion on the pigtails where the bulbs go.
Old 04-11-2009, 10:15 AM
cookba's Avatar
i've replaced the bulbs several times and that always fixed it. but ya check for corrosion too
Old 04-11-2009, 10:36 AM
99T/A_Marine's Avatar
The flasher for the turn signals is on the left side under the dash, hidden by a "wall" right beside where the fuse box runs. Should be clipped in place like the one for the hazards. Also, it may be the sockets for the front turn signals. Both of mine went out at the exact same time about a month ago. Check the bulbs, then the flasher, and then the sockets.
Old 04-11-2009, 10:59 AM
slayerized6's Avatar
if theres corrosion in the socket, you need to change the socket
http://www.ls2.com/forums/showthread...threadid=15143
Old 04-11-2009, 11:04 AM
tnmotown's Avatar
cool, thanks guys! Im off to the store to get some bulbs
Old 04-13-2009, 03:23 PM
slow's Avatar
sounds like a ground, could be as far as the taillight harness, but I've seen it traced down to a bad ground before.
Ryan
Old 04-13-2009, 03:51 PM
check the socket for corrision; thats what kept my signals stay lit
Old 04-13-2009, 05:36 PM
tnmotown's Avatar
it was the bulbs. they were burnt on both sides. replaced them and work good now. thanks guys!
Quick Reply: Why my turn signals stay lit up on dash??
