General Maintenance list
1997 Camaro Z28 134k miles automatic. STOCK
1: Engine
- What is correct oil weight and how many quart ?
- Should I stick with regular pennzoils or mobil 1
- What is best oil filter, should I stick with ac delco ?
- What kind of spark plug do I need ? should I stick with ac delco, I want something that last and I dont want change it out soon.
- What is best spark plug wire to get ?
- What fuel filter brand should I use ?
2: Automatic Tranmission
- What kind of tranmission do I had ?
- What is the correct fluid for my tranny ? regular or synthetic
- What is best brand for automatic tranny filter
- How many quart do I need when I drop the pan and change out filter.
- Its good ideal to install an aftermaket pan with drain plug ?
- this is first time I drive a automatic, why their is 2 letter D ? and which one I should use ?
3: Gear
- What is correct oil weight for my rear diff. Regular or synthetic ?
- Does my Diff have LSD or posi ?
- How many quart do I need for my diff ?
is their a online site that show how to do these thing with picture ?
Where I can buy cheap OEM part and aftermarket part online ? I know its alot of question, im new to camaro and I want to learn how to take care of it much as possible, please help, thank you and have a nice day.
1: Engine
3: Gear
for plugs and wires, a member on here sells msd wires with ngk tr55's or tr5's for a good deal. user name is "blanco ss" i believe. just specify that your wires need to be cut to fit an lt1
oil...most prefer mobil 1, german castrol, royal purple and high priced synthetics. 10w30 or 5w30 is often use for ls1's, not sure about lt1's
1: Engine
5 quarts of oil, 5w30 or 10w30 should work fine
i have always used pennzoil with no problems.. but it depends on who you talk to really..
ac delco makes some good filters, its generally accepted that any filter will do fine if its not a fram
a lot of people use NGK's.. i stick with ac delco personally
doesnt really matter IMO
any filter will do
you have a 4l60e
not really sure, i use dexron III in my manual
~5 quarts, just keep filling until it is full with the car running and in neutral
sure, if you want, a bigger pan will help wit cooling the transmission to fit more fluid in
use D, the other D's are so you can shift it manually
3: Gear
i used 75w90 in mine, remember to add the LSD additive
LSD and posi are the same thing, posi is just a name GM came up with for LSD
dont remember how many quarts it had, but just keep filling it up until it starts to come out of the fill plug
check out install university
1: Engine
any filter will do
you have a 4l60e
3: Gear
Actual capacity is 5.5 quarts for the engine.
I usually save the leftover 1/2 quart, then add it when needed.
I plan on going to the larger PF61 filter next time, so I'm just going to add all six qts at once.
assuming since he has a 97, im guessing its an lt1, which would be 5 quarts
