I tried a diff DRL bulb than normal, results inside - LS1TECH
Thread Tools Search this Thread
Old 04-20-2009, 08:57 PM   #1
sneaky7980's Avatar
Default I tried a diff DRL bulb than normal, results inside
I went out to replace another burned out drl in my 99 T/A today and realized that i accidently put 3757's in last time. From what i've turned up here using search and looking on some car parts websites, 3157's and 3457's are okay but nothing came up abut 3757's.
Now the interesting part, the lights function differently with diff bulbs.
Examples;
3157's
-ignition on, s/w off = dim
-ignition on, s/w in park = dim
-ignition on, s/w on = off
3757's
-ignition on, s/w off = bright
-ignition on, s/w in park = bright
-ignition on, s/w on = dim
I can't remember if its normal for them to be off when the headlights are on. If that's normal then i like the results of the 3757's better.
To ease my mind, can someone verify tell me if that's the proper operation for the 3157's?
sneaky7980 is offline   Reply With Quote
Old 04-20-2009, 08:57 PM   #2
sneaky7980's Avatar
Also now that i think about it, when i last changed these bulbs i changed the sockets also. I remember the bulbs had to be "modified" to fit. I assumed it was a defect in the cheap sockets at the time and assumed that the bulbs were correct.
Unless anyone knows of a good reason i shouldn't use the 3757's, i think i'll switch back to them and post some pics.
Old 04-21-2009, 01:51 AM   #3
_JB_'s Avatar
Quote:
Originally Posted by sneaky7980 View Post
3757's
I must be tired, what does s/w mean? I don't know what bulbs I have, but mine go:
Ignition on, parking brake off=Bright
Ignition on, parking brake on=Off
Ignition on, parking lights on, parking brake off=Bright
Ignition on, parking lights on, parking brake on=Dim
Headlights on=dim
_JB_ is online now   Reply With Quote
Old 04-21-2009, 02:24 AM   #4
Joshiedoom's Avatar
Question is how much heat are they putting out?
Joshiedoom is offline   Reply With Quote
Old 04-21-2009, 06:15 PM   #5
sneaky7980's Avatar
Quote:
Valid point.
S/W stands for switch, sorry.
Old 04-21-2009, 07:44 PM   #6
Joshiedoom's Avatar
Valid point.
Ive got super shitty DRLs so hell I would try it as long as it doesnt burn my car down :
Tags
1998, 3457, 3757, bulb, bulbs, drl, led, ls1, ls1tech, pontiac, size, stock, switchback, tech, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
