*** Car dying randomly PLEASE HELP!!!! ***
Old 05-01-2009, 09:08 PM
TLUZLS1's Avatar
Default *** Car dying randomly PLEASE HELP!!!! ***
Not really lsx related but hope someone might be able to give quick insight. A friend has an 02 oldsmobile alero and they were driving down the highway and the car shutoff and the battery light and oil light came on at the same time. She pulled to the side of the road put it in park and it started right up. She drove another 2 or 3 miles and the same thing happened. Fired it up again and it's been driving fine for about 20 miles or so. Anybody have ANy clue?? im lost on this one, maybe a failing ignition switch? But then there is the oil light that came on? I asked and she said the car sounds fine and is driving normally (no clunks, ticking, tapping or whining). Please help!
Old 05-01-2009, 09:10 PM
TLUZLS1's Avatar
EDIT: The problem just happened again...
Old 05-02-2009, 09:25 AM
slvr98camaro's Avatar
the oil light and battery light came on because the car stalled and the pcm threw the dummy lights for the alternator/battery and oil pressure
Old 05-02-2009, 09:36 AM
firetpi's Avatar
Hows the crank sensor connector? How many miles/how old is the car?
Just a quick thought of the crank sensor taking adump
Old 05-02-2009, 10:00 AM
slayerized6's Avatar
is it throwing a check engine light?
Old 05-02-2009, 08:34 PM
TLUZLS1's Avatar
So by dummy lights you mean they came on for no reason or there is a power or oil pressure problem? I thought they indicated a problem?
I don't know about the crank sensor. It's an 02 with 73k miles.
No only right when it shuts off.
Old 05-02-2009, 09:49 PM
Choppers's Avatar
My friend picked up a buick with 90k miles from his grandpa. same thing was happening to him. We were on the way to the mall when the car did it twice and then the next time it started knocking when he started it. never diagnosed cause the grandpa gave him the money back and junkyarded the car but. the problem was never diagnosed but i suspect the oil light was not good meaning oil pressure was real low.
Old 05-05-2009, 02:26 PM
BlackHawk256's Avatar
Check battery cables for proper connection or corrosion. If they are ok, it's the alternator which is going out, and will need to be replaced.
Old 05-05-2009, 02:45 PM
Injected1's Avatar
I disagree with the alternator. If the alternator was going out the battery would have been dead when the car died, thus not re-starting.
I am betting on Crank/Cam position sensor, check her fluid levels, but I doubt it's truely an oil problem. It's crank trigger ignition right? Individual Coils? Definiately a sensor imho.
Old 05-06-2009, 12:06 AM
Yeah your right, it would've never came back on....hmmm
