Z28 is becoming Harder to start...Starter?
Old 05-10-2009, 08:18 PM
AgentLS1Z's Avatar
Default Z28 is becoming Harder to start...Starter?
My LS1 just hit 82K miles. When I go to start the car it doesnt start up as immediately as it did a couple days ago. It seems like the engine turns over just as quick as it did but i have to hold the key a tad bit longer...Anyone know what my issue is?
Old 05-10-2009, 08:43 PM
fuseone's Avatar
If its still turning over fine then it wouldnt be with the starter or battery. possible fuel then. If it was the starter it wouldnt want to turn over.
Old 05-10-2009, 08:51 PM
AgentLS1Z's Avatar
yea..i was kinda driving like a jackass a couple days ago because i was running late. i get a misfire on cylinder 4 occassionally like every couple months but it did come on a couple days ago as well...i changed my plugs and wires last year and coil pack. Maybe i need a fuel injection service?
Old 05-10-2009, 10:31 PM
Save the manuals!
wssix99's Avatar
Your battery could be going out. You may take it to an auto parts store and get it tested to see how many CCA you have left in it. As the weather gets warmer, it could totally crap out on you if its starting to loose capacity.
Old 05-10-2009, 10:32 PM
hitmanws6's Avatar
+1 on the battery, happened to me last week
Old 05-10-2009, 10:36 PM
AgentLS1Z's Avatar
hmm, ill get it checked out. I recently gave 2 people jump starts...maybe thats what killed it?
Old 05-10-2009, 11:31 PM
hitmanws6's Avatar
doubt that would do it. any drain would be recharged by the alternator. how old is the battery and what brand is it?
Old 05-10-2009, 11:47 PM
AgentLS1Z's Avatar
ive had the car for about 3 years and havent changed the battery. idk how old it is...not sure of the brand, but yea its prob a cheap *** one
Old 05-11-2009, 12:07 AM
killagt's Avatar
I do get interstate battery, or cheap would be duralast gold. My friend ran duralast gold in his 600+ cobra and he swear by it.
Old 05-11-2009, 12:31 AM
hitmanws6's Avatar
go with die hard or optima. interstate does not have enough CCAs for our cars, duralasts tend to leak a lot
Old 05-11-2009, 07:28 AM
NonGoggleGuy's Avatar
Just get 8 double-A Energizers and put them in series to get 12V. That's cheaper than buying a whole new car battery.
Old 05-11-2009, 10:30 AM
loyolacub68's Avatar
If you have any aftermarket stereo equipment in your car I'd go with a red-top Optima, if you like to use your stereo a lot with the engine off go with a yellow-top, finally if its your DD and you have no aftermarket stereo or no plans for one go with a die hard or duralast from your favorite auto parts store.
Old 05-11-2009, 11:16 AM
AgentLS1Z's Avatar
thanks for all your input, the car currently has an ACdelco battery in it...It started up fine today, but ill be lookin into a new battery
Old 05-11-2009, 12:42 PM
LS6427's Avatar
Corrosion build-up can also cause hard starts. One day it'll be fine, the next it could stumble. Check all your ****.
Old 05-11-2009, 12:49 PM
dlove's Avatar
check fuel pressure at start up. The pressure might be bleeding off after key on and take a second to come back.
Old 05-11-2009, 12:54 PM
DRGnFLYZ28's Avatar
If you decide to get a new battery, may I suggest an Optima Red Top.
Best battery I've ever had... and I've used many including AC Delco, Interstate, Die Hard and Exide.
Optima Red Top
Group Number: 75/25 (8022-091)
RedTop®; Battery; UNBOXED; Group 75/25; Cold Crank Amps 720; Crank Amps 910; Reserve Capacity 90; Ampere Hour 44; Dual Terminal; L-9 5/16 in.; W-6 13/16 in.; H-7 5/8 in.;
Old 05-11-2009, 01:01 PM
+1 on the Optima per the reasons above. I have a yellow top and its been in 3 different vehicles going on about 6 or 7 years. Best battery ever. No leaks and I've drained it completely 2 or 3 times.
Old 05-11-2009, 08:42 PM
fuseone's Avatar
Not to question the rest of yous but if he is saying its turning over normal how could that be the battery?
Old 05-11-2009, 08:53 PM
LS6427's Avatar
True.
Until he gets both the battery and the alternator tested, this thread is waste of time.
It could be an alternator on its way out too. Sometimes it will charge the battery fine and sometimes it won't, which would explain the occassional hard start, then the easy start.
