water pump
Old 05-11-2009, 06:54 AM
peterock98's Avatar
Default water pump
Will a water pump from 04 gto work on my 98.
Old 05-11-2009, 07:18 AM
NonGoggleGuy's Avatar
Yes, it should fit. They don't make the LS1 WP anymore, so I think they sell the LS2's as a replacement. Ask the dealer.
The only difference is that the t-stat housing is different on the LS2.
Old 05-11-2009, 08:01 AM
peterock98's Avatar
Thanks this one was hardly use they went with an electric water pump.So I have an old hyper tech T stat from early 2001 is when i changed it should bolt on the 04 gto's were ls1's correct
Old 05-11-2009, 08:03 AM
No, the LS1 WP t-stat housing is the housing & the t-stat all in one (1 part).
The LS2 T-stat is completely separate from the huosing itself (2 parts).
Old 05-11-2009, 08:05 AM
Oops. Just re-read that. Yes, you are correct - the '04 GTOs were LS1, so everything should be interchangeable. Sorry.
Old 05-12-2009, 05:54 AM
peterock98's Avatar
no sweat
Old 05-15-2009, 10:59 PM
peterock98's Avatar
https://ls1tech.com/forums/conversio...waterpump.html
I got an ls2 pump I'am worried about the pulley will the belt stay on it.
