My '98 Camaro wont start after wither storage. - LS1TECH
Thread Tools Search this Thread
Old 05-16-2009, 10:51 AM   #1
The Crazy Sweed's Avatar
Default My '98 Camaro wont start after wither storage.
Hi!
I have a problem with my í98 Z28 Camaro 113kmiles, it wonít start.
When I parked the car in October the car was running great and nothing unusual was noticed. I parked it and left it open, no alarm running and the battery connected.
In December the power to my garage was cut due to a broken cable, so I had no power until early march. The battery was still connected because I forgot to disconnect the cables. I didnít disconnect it until in late January, by then the battery was empty (a 4months old Optima Red top battery) I charged the battery and I was afraid for the battery being damaged due to the low power and cold whether.
Anyhow I ran a test on the battery and it was ok, so I mounted the battery fully charged. I put the key in the ignition and tried to fire it up, I didnít notice anything different (the gauge cluster was not installed due to 6LE//McNord gauge install). The shift light was lit up as usual, and the traditional PING was there and I also heard the fuel pump (I think, sounds like a humm). And when I turn the key further for start-up but nothing happened just a small click.
A notice is that all electrics in the cab works, fans, stereo, lights and sow on.
I have cheeked all the fuses and I have even tested with a brand new battery but the same thing happens. I have not done anything with the car since I parked it except for removed the gauges and headlights.
Does any one recognise the problem? Or have any idea of what it could be?
Is it an ECM problem or can it be an electric problem (start lock?)
I installed a í99 gauge cluster can this have damaged some thing?
Any help is extremely appreciated!
Thanks, Anton
The Crazy Sweed is offline   Reply With Quote
Old 05-16-2009, 11:26 AM   #2
bad battery is my guess
has enough power to run your accessories, but not enough to turn the engine over
slvr98camaro is offline   Reply With Quote
Old 05-16-2009, 04:33 PM   #3
I have already tried with a brand new Optima battery.. nothing else hapened.
Old 05-16-2009, 06:27 PM   #4
Quote:
so even with the new battery it is still clicking?
clean the terminals up good and try again
Old 05-16-2009, 07:08 PM   #5
duh
duh's Avatar
sounds like a starter......common problem with stored cars. If you turn the key and get the click that's the solenoid trying to kick the starter. If you get nothing at all then the solenoid is bad. Down side is the solenoid is the small part on the top of the starter... either way sounds like a starter.
Good luck
duh is offline   Reply With Quote
Old 05-19-2009, 01:22 AM   #6
The problem was even more simple than that.. i have changed the gauge cluster for a'99unit. And what i didn't notice was that the new cluster blew a fuse in the small fuse box on the dash. When that fuse (marked with gauge) is broken you cant start the car.
Problem solved..
Does any body know if i can get the '99 cluster to work if i accses the computer?
Related Topics
Thread Thread Starter Forum Replies Last Post
need help diagnosing No Start Arctic_Z General Maintenance & Repairs 13 01-16-2016 10:30 AM
Urgent - clicking noise when connecting battery chronos LT1-LT4 Modifications 15 01-01-2016 04:18 PM
Battery Wire Threaded Terminal Predator Stereo & Electronics 10 12-15-2011 12:49 PM
Alternator/Battery Problems On 2000 LS1(Detailed story) camaro981289 General Maintenance & Repairs 20 11-23-2010 09:19 PM
No gauge no ignition No Start When turn the key.. HELP!!!!! ZSU LT1-LT4 Modifications 6 12-17-2007 07:17 PM
Tags
98, 99, battery, blew, camaro, car, click, disconnect, fuse, rs, start, starting, storage, turns, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
