Sweeping Gauges
Sweeping Gauges
This just started happening, the past couple days. At WOT, car loses power, the gauges sweep, like i just turned the key into the on position, after gauges sweep, car is back to life. Any ideas?
i seem to recall this happening to someone on here, two different times
one time it was the alternator was bad, and another was the wire on the back of the alternator was dirty/disconnected, as were the battery terminals
check those connections first and clean them good and see if the problem is still there
it may be a bad battery, or an alternator that is about to go out.. but can also be bad wiring somewhere or a bad ground
i checked all the connections on the drivers side... they were all good.
Any other ideas?
How many "grounds" does there have to be ? I've heard both sides of the block, and both heads have to be grounded. Can these areas share the same ground ?
Any other ideas?
Can i just install a new ground at the front of the head to test it out? Does each head, have to have it's own ground? Do these grounds goto the battery of the frame, or body?
