Help loud noise
Help loud noise
I was just drag racing my 98 SS 6 speed and i took off fine. Chirped 2nd and 3rd gear then when I hit 4th gear I let out the clutch and there was a loud noise which seemed to come from the rear end and it violently jerked the car at around 85-90mph so I let off. I'm worried about this and there are no leaks or anything coming the car. The car still drives perfectly fine on the road. This only happened 2 out of the 4 times I raced. My mods are LS6 intake, !EGR, Lid, Custom ram air, cutout, flowmaster catback, all free mods. Does anyone know what could be wrong with my car? Slipping clutch? Any help will be appriciated.
Thanks
Thanks
I would pull the cover off the rear end and inspect the teeth on the ring gear and pinion. I dont know how many gear sets i have seen break on a 10 bolt. I drove my car for another 6 months with this problem until i changed the fluid and a tooth was missing off the pinion. Its an easy and cheap check.
i was racing with Zexius 275/40/17 street tires and they don't hook for **** i spin them all though first launching at 2000rpm at 25psi.
It probly isnt my exhaust since its all stock except my catback and the car only has 65,000 on it. But I was also thinking it might be my clutches in my rear end going out.
