need help
Old 05-21-2009, 08:38 PM
kraemer94's Avatar
Default need help
My DD a 1995 Camaro decided to take a dump on me today. Car will not start and also will not shift to N,D,R nothing when I press the brakes. This is a auto by the way. I here a tick sound once when I turn the key all the way but nothing. I check my Battery it's reading 12.5V lights radio works. Check battery connections all good. I'm thinking it's the shift solenoid but would this stop it from starting even if it's in park?
Old 05-29-2009, 09:05 PM
kraemer94's Avatar
Well I got the car shifting, but still does not start. When I turn the key to on I hear a click then when I turn it all the way to start nothing. Thinking it might be the starter. Looks like a pain to change out. The cross over pipe is running right under it.
Old 06-01-2009, 09:00 PM
kraemer94's Avatar
Well it was the starter,I changed it out this weeked PITA but got it done, But now I have another issue Now both air bag and the abs light is staying on. brakes are working ok as for as I can tell. Has anyone else have or had this problem. I did check all the fuses, brakes etc. all good.
Old 06-01-2009, 09:07 PM
LS6427's Avatar
Maybe reset the PCM
Old 06-01-2009, 09:21 PM
kraemer94's Avatar
Ya, I did that as well, Even went as far as reseating all the fuses.
