A/C cabin control question....fan motor resistors
Old 05-30-2009, 10:30 PM
LS6427's Avatar
Default A/C cabin control question....fan motor resistors
My step fathers parents...in their 90's...have a 2000 Pontiac Sunfire. I assume they are the same fan motors and selector switches as our F-Body's.
They do not have #1 or #2 fan speeds, fan does not turn on. But #3 and #4 fan speeds work fine.
What can I do for them to fix it? Does it simply need a totally new fan switch?
Thanks
Old 05-31-2009, 06:57 AM
slvr98camaro's Avatar
spray some wd-40 in the switch and wiggle it around a bit
i have an old car that sits 99% of the time and had a similar problem (mine only worked on high)
but that fixed my problem
Old 05-31-2009, 08:37 AM
Formula413's Avatar
Almost certainly the blower motor resistor. It's probably behind the glove box.
Old 05-31-2009, 12:19 PM
blower motor resistor should only work on high if it is bad.
Old 06-01-2009, 08:34 AM
Formula413's Avatar
I think I've heard of them losing one speed at a time.
