D.R.T...Done Right There. Help please!
Old 06-05-2009, 12:22 PM
GeeterOne's Avatar
Unhappy D.R.T...Done Right There. Help please!
I have a stock 01 WS6 with about 80,000 miles, auto. Went running around for a day of hookie the other day, business as usual. Car ran fine no problems. Came home from the bar, parked in the garage, and went to bed.
The next morning I get in it, turn the key and nothing. I mean nothing. No click, click, click. Nothing. Battery is good. Lights, tunes, wipers, dings, etc. are all good.
It acts like it's in gear while trying to start, but it is not. No warnings just complete failure.
Any help much appreciated.
Oh yeah, if not obvious, I am seriously mechanically challenged.
Old 06-05-2009, 12:37 PM
SSInnovations's Avatar
Check the fuses?...
Old 06-05-2009, 01:36 PM
GeeterOne's Avatar
Yeah, checked fuses. Checked battery terms. and connections.
Old 06-05-2009, 01:41 PM
SOMbitch's Avatar
Maybe the brake switch. Also does the indicator line up on park.
Old 06-05-2009, 01:55 PM
GeeterOne's Avatar
What do you mean brake switch? Yeah indicator lines up on Park. Also tried in N with same result.
Old 06-05-2009, 03:19 PM
01CaMMMaro's Avatar
im gonna say fuel pump... if it tries to crank but never turns with no clicking and all the lights and electric work then i would say fuel pump.
Old 06-05-2009, 03:37 PM
GeeterOne's Avatar
It doesn't try to crank. It does absolutely nothing when you turn the key. It acts as if you are trying to start it in a drive gear. I take that back...when you turn the key, the tunes and dings and lights and gauges all act normally but, that is all that happens.
