Car is Stumbling at low rpm, seems like 4cyl, Help !!
Old 06-07-2009, 10:29 AM
3800RS's Avatar
Default Car is Stumbling at low rpm, seems like 4cyl, Help !!
Dont know whats going on. this past week all i did was take out the ac compressor, and fix my rubbing header.
- All plug wires seemed on, coils are getting power
- Batt was out for a day
- Batt is kinda weak but i dont think that weak
When i start the car it sounds normal, go to drive and its super quiet, stumbles from a stop and just like putters. If i give more gas though it kinda kicks in normally.
What can be the problem here ?
Old 06-07-2009, 11:14 AM
98Camarod's Avatar
Throwin any codes? If the battery doesn't have the correct voltage, that affects fueling.
Old 06-07-2009, 06:28 PM
3800RS's Avatar
battery being weak can affect it even though the alternator is putting out 13.3 ? no codes being thrown either
When i test the batt with all off volts read 10.9
Old 06-07-2009, 07:14 PM
98Camarod's Avatar
If the voltage from the alt is right then I don't think there would be a problem. Are the cables tight on the battery? Check your grounds and make sure they are clean and tight.
Old 06-07-2009, 07:58 PM
3800RS's Avatar
idk i am thinking it is something i did on fri when i adjusted the header
Old 06-07-2009, 08:28 PM
98Camarod's Avatar
Only thing that I can think of around the header is the engine coolant temp sensor, did you break that?
Old 06-08-2009, 07:25 AM
3800RS's Avatar
nope, ect is still reporting to my aeroforce gauge.
Is there a chance maybe a plug wire got broken and i cant see it ? No codes though
Old 06-08-2009, 02:14 PM
Marc 85Z28's Avatar
Loose wire? Cracked plug?
What do you mean by 'adjusted header', they're not adjustable as far as I know!
Old 06-08-2009, 04:34 PM
98Camarod's Avatar
If you rested the header on the plugs there is a chance that a plug or plugs got cracked. Also a possibility that the plugs aren't seated all the way. If you have an extra set of plugs I'd change them out since a hairline crack is hard to see. Try looking at it running in the dark and see if you see anything arcing.
Old 06-08-2009, 04:40 PM
3800RS's Avatar
replaced batt today. I am swaping a few old o2 sensors to see if that helps. All i did with the header was loosen all bolts, moved it a tad away from the frame and then re-tightened it.
It seems when i first start the car (open loop) its ok. Wait about 45 seconds and its screwy.
I think i am gonna order new wires and plugs to rule that out. Can it be injector or fuel problem. I have a aeroforce gauge that can read out the pulse width and what not if needed.
Old 06-08-2009, 08:40 PM
3800RS's Avatar
after swapping in some old o2 sensors and moving around the plug wires it seems fine.
Took it for a quick ride no problems. I am gonna change out all plugs and wires for added security
Does anyone know the part number for the 2 delco o2 sensors ?
Old 09-29-2009, 12:09 PM
3800RS's Avatar
i think the cause might of been the harness that runs down the frame on the pass side by the header. There was some burnt wires in there and i think when i wash the car water screws it up. Re-did the harness and it seems fine
Old 09-29-2009, 03:35 PM
Ryanmgaspard's Avatar
I don't have headers but have the same problem. No codes just the stumbling at low rpms. I replaced the plugs and wires this weekend and the problem didn't go away.
Old 09-30-2009, 04:04 PM
Jayh's Avatar
Same problem here. I think its the O2 sensors because Im throwing codes.
Old 09-30-2009, 10:24 PM
98pontiac's Avatar
bad 02 sensors should not cause the car to stumble at all... they should not cause any drivabilty problems... if it is related to headers, check the egr system for proper seal on the manifold and on the headers.
Old 10-01-2009, 08:39 AM
3800RS's Avatar
it was def an electrical probllem. I havent encountered it again however. If you would get water in the right place it would screw it up
Old 10-27-2009, 10:39 AM
Jayh's Avatar
I replaced my o2's, eliminated the inital stall from a stop, but I still sputter while maintaining any RPM below 3K. If I gas it, it goes.....Im throwing a MAF code. Could that be the culpret? It seemd to run better as the weather cools down, I think it was causing ot to run prett rich.
Quick Reply: Car is Stumbling at low rpm, seems like 4cyl, Help !!
