Driver side window...
Old 06-14-2009, 04:30 PM
Nick_Rapitis's Avatar
Exclamation Driver side window...
keeps stopping and then wont go back up or down for a few minutes then stops again and so on...bad motor? easy fix?
Old 06-15-2009, 08:35 AM
z28_n_tx's Avatar
mine does the same thing....i believe our window motor will soon go.
Old 06-15-2009, 12:02 PM
Danny2tek's Avatar
yes those are the signs of our failing window motors
Old 06-15-2009, 01:56 PM
Sunset01TA's Avatar
Yep replaced a bunch its going south.
Not to bad to fix.
First time may take you a bit of time.
Old 06-15-2009, 05:02 PM
z28_n_tx's Avatar
Not to bad to fix.
where can i get the cheapest one??? and i know ive seen a write up some where buct i cant find it.
Old 06-15-2009, 09:13 PM
3800RS's Avatar
ebay......
Old 06-16-2009, 10:06 AM
do you have to replace the regulator at the same time or just the motor?
Old 06-16-2009, 11:44 AM
Danny2tek's Avatar
just the motor
Old 06-16-2009, 01:10 PM
USArmyZ28's Avatar
Definately motor, I get my replacements at auto zone for like 40$. Pretty easy replacement.
Old 06-16-2009, 01:20 PM
WSsick's Avatar
not to hijack, but mine is kind of doing the same thing. but the only time i have problems is if it goes all the way down, but if its even an inch above that, it comes up every time. motor or regulator?
if someone has an answer, PM it, so we dont take away from the OP's thread.
Old 06-16-2009, 02:34 PM
slt200mph's Avatar
I went to advance Auto Parts and bought a new window motor for $29 with a life time guarantee..it took about 45 minutes to replace the old motor..that was 2 1/2 years ago and the window is still moving fast...the aftermarket motor is much better than the factory motor that came in the car.. Just go and buy a motor from the cheepest auto parts store (check prices on line) and don't bother with shipping and all the other crap ya have deal with on ebay ... replace the motor and be done with it...... check out this link for a how to do it with photos ...
http://shbox.com/page/windowmotor.html
Old 06-16-2009, 02:40 PM
did th emotor come with new rivets?
Old 06-16-2009, 02:59 PM
slt200mph's Avatar
No it came with nuts and bolts and I used the high strength Loctite (red) had no problems at all after 2 1/2 years... you could use an aircraft locking nut with the nylon incert if you needed more peace of mind ... I'd just Loctite it and forget about it.
Old 06-18-2009, 04:51 AM
Jeff Smith's Avatar
Great write-up...
