AC not as cool as can be. Recently serviced...
Old 06-19-2009, 10:37 AM
Nelapse's Avatar
Default AC not as cool as can be. Recently serviced...
I had a leak in the schrader valve, so I replaced it. Vacuumed the system and added some high mileage r134 to the proper pressure. The air blows okay somewhat cold, but I know it should be better.
Should I try replacing some components?
Or try the synthetic 134's?
Anyone have some insight.
Old 06-19-2009, 10:44 AM
samson_420's Avatar
What is high mileage 134a? < Crap
Check your pressures. . .
Old 06-19-2009, 11:27 AM
Nelapse's Avatar
pressures are in the blue.
Old 06-19-2009, 11:41 AM
samson_420's Avatar
Blue what?
Old 06-19-2009, 11:48 AM
Nelapse's Avatar
Blue section on the Gauge manifold set.
~ 45 psi of pressure for the 134.
Old 06-19-2009, 11:50 AM
jmilz28's Avatar
What the hell are you comparing? You are being faaaaar to general, zero detail. Let me help:
What is the outside temp and humidity at time of test?
vs.
What is the output temp at the center vent? Take this after 5-10 minutes of cool down time.
What is the delta between the two? This will tell you the relative performance of the system.
Old 06-19-2009, 07:30 PM
samson_420's Avatar
As long as the magical gauges are in the "blue" it should blow ice cubes.
Come on, really?
