need helpppppp !!!
need helpppppp !!!
Ok so heres the story as i was driving around new orleans i shifted into second and then my car dies i open the hood to find out my positive battery terminal has been melted i have checked ground wires on everything, replaced battery, alternator, i took the starter in and the voltage regulator failed so i replaced that too, and also i replaced the crankshaft sensor, checked the fuel pump and it comes on when i turn the key, has spark and is getting fuel..itll crank up but wont start and when i look at my gauges the batterly level is extremly low for a brand new battery...what are some other things i could check or look at to solve my problem ???
i had the battery tested and i have an extra battery put in there that tested good also, and the cable is fine its the terminal on the battery that melted and i got rid of it.......thanks though
